| diyAudio Sponsor | ||
Hey All,
Not much luck doing a search on this one.. Trying to decide what size chassis I need to buy. Besides the space for components inside, another factor is tube placement. Obviously the more space between tubes the better for keeping heat down, but can anyone offer a basic rule of thumb for minimum distance between power tubes (PL519s in my case - if tube type matters) so they have adequate cooling? Thanks! |
#3 |
If you can't find a recommendation on the data sheet then a rule of thumb seems to be 1x to 1.5x the tubes' envelope diameter. I've also seen that same range applied to the distance between output tubes and the OPT.
--Sherman |
#4 |
A recommendation for the very hot 6C33 by many who have experience of it, is 3 inches clearance. This tube has a rep of burning sockets though.....
The PL509 may not be quite as hot, but three inches should be quite enough without making the chassis too big, unless you plan an OTL with herds of tubes! ...
Das Beste Oder Nichts |
#5 |
According to convection laws no less than 8 mm between tubes. The more the better, but more significant is a good path for convection, i.e. free flow of the air from bottom to top. In this my tube amp project I designed it such a way so tubes also suck the air from transformer compartment:
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#6 |
Very nice look. wavebourn. It seems that the mesh also would keep the heat a bit separate between the tube / xfmr areas as well as hide the iron.
How did you design the side panels, is that just custom-cut sheet metal with padding & vinyl glued over it, or a fancier combo? Looks great |
#7 |
this bit of thermodynamics (which I have been trying to figure out for a long time) really puts a damper on my plans for a Tube Amplifier/ bread toaster...
#8 | ||
It is made of an old wooden shelf covered by thin foam and leather imitation. xformer area has grill on bottom of the rear panel, so air goes from rear to front. Also, you may see aluminum mirror under the front grill. Quote:
Before that common sense matters.
| FS:Power Tranny, Tubes | audiopro | Swap Meet | 2 | 13th January 2008 03:34 PM |
| Guitar Amps, Overdrive Pedals, and Space Charged Tubes | Turbo7MN | Tubes / Valves | 14 | 13th November 2006 11:38 PM |
| a bit of power, space and money | mark_titano | Multi-Way | 0 | 27th November 2004 01:53 PM |
| Power Tubes | s2kov | Tubes / Valves | 6 | 18th November 2004 09:23 AM |
| low voltage tubes (space charge, etc.) for guitar amp? | needtubes | Tubes / Valves | 4 | 31st October 2003 12:45 AM |
| Page generated in 0.08832 seconds (78.78% PHP - 21.22% MySQL) with 10 queries |
