| diyAudio Sponsor | ||
I have VAC 80/80 KT88 amp. After adjusting bias so that plate current is exactly same, I can hear some hum from speakers. If I adjust bias by ear I can get that hum to disappear. But plate currents differ quite much then. 63 mA and 65 mA for other pair and 52 mA and 65 mA for another pair.
Which one is better? To adjust bias by ear to get minimum hum or to adjust by meter to get identical plate currents? My amp is working in triode mode and is biased towards class A to get best sound quality. Sincerely Yours, Sixtus Oest |
#2 |
When you discover something like that it indicates that having the valve off-balance is introducing a small hum signal that is cancelling the hum out. If you can't find the true source of the hum and beat it directly, I say go with your ears
#3 |
diyAudio Moderator Emeritus
I am not familiar with the amp. One possibility is that you are measuring voltage across cathode resistors that are not accurately matched. Another is that the primary winding of your OPT is not tapped exactly in the center. Whatever the problem, it's usually best to balance by ear,
| Adjusting the BIAS for Threshold SA3 | sonic22 | Pass Labs | 9 | 16th May 2011 12:38 PM |
| 400A bias adjusting | Mywing | Pass Labs | 7 | 25th May 2008 07:53 PM |
| Marantz pm 94 + Bias adjusting | CederPM94 | Solid State | 0 | 10th May 2004 09:22 AM |
| Adjusting DC bias for Zen amplifier | hlvan | Pass Labs | 6 | 5th November 2001 07:43 PM |
| Page generated in 0.06643 seconds (76.74% PHP - 23.26% MySQL) with 10 queries |
