| diyAudio Sponsor | ||
Ok I'm sure this is a easy questions for most of you guys but how do I figuare the
primary resistance needed for a output transformer. Should it be the resistance of the plate load or not. Im looking at 2500 vdc at 317ma. Oh it's not a normal audio tube. Any help would be greatly appreciated. |
#2 |
I think what you are asking for is how to determine the "impedance" not the "resistance".
For a single ended triode (SET) application, the simple rule of thumb, as a starting point, is to use a primary impedance of 2x (two times) the Rp (tube's plate resistance) at the chosen operating point - you can get this data (either directly or derived from the curves) from the tube data sheet. For a push-pull (PP) application the impedance should be 4x the plate resistance. I hope this helps, -- josé k. |
#3 |
Ya I knew about impedence or Z: but I was being generic anyway's thanks for the info.
Nick |
#4 |
Shut I know double posting is a no no but it's a tetrode not a triode.
#5 |
Just decide what class you want it to run in and draw a load line:
http://www.freewebs.com/valvewizard1/se.html |
| Op amps: output impedance and load resistance | mudihan | Chip Amps | 17 | 20th April 2009 08:09 AM |
| Output transformer DC resistance.. | jpdesroc | Tubes / Valves | 6 | 12th March 2008 09:46 PM |
| ear 834p output resistance | FTSIKIS | Tubes / Valves | 5 | 10th May 2007 09:26 AM |
| I want to make an amp with a Negative Output Resistance, but HOW?? | CeramicMan | Solid State | 26 | 3rd June 2004 02:45 PM |
| Page generated in 0.08246 seconds (71.86% PHP - 28.14% MySQL) with 10 queries |
