| diyAudio Sponsor | ||
Does anyone recommend this Schematic ? try googling but could not find that high output.
anyone ? cal
be tube |
#2 |
You will not get 35W from a pair of triode strapped KT88/6550's. class A.
#3 |
diyAudio Moderator Emeritus
As said in the other thread, you really need two pairs of 6550, in parallel PP, to get this much power in triode-mode. (If you were prepared to use ultralinear connection, then one pair of 6550 would be enough.)
#4 |
6550 40W se
Maybe you should have a look at this project. The designer and builder (jane) is also a diyaudio member. He has done many amps, and I`ve read on a norwegian forum that this one sounds very good. |
#5 | |
Yves. |
#6 |
the 3x6550 only 24 W in triode mode.
where is the triode and Ultra linear switch ? I need more POWER on triode mode. but this schematic is so simple.... I don;t think I can get the sowter OT anywhere locally except from ebay. that's costly. I wonder how much it cost to create this project ? cal
be tube |
#7 |
If you REALLY need more power, forget triode and single ended.
Two 6550 will give you more than 60W in penthode mode at much lower cost. Yves. |
#8 |
yes but I really need the triode mode, because of the sound quality reason.
why doesn't anyone design that triode high power ? must be very very difficult ? cal
be tube |
#9 |
calico88,
Going SE whatever tubes you use by paralleling more than 2 is costly and need perfectly matched tube pairs or triplets or quadruplets. {And in those cases tubes must be replaced more often} From a DIYaudio point of vue more than 2 will become instable and will need potentiometers in each cathode to adjust bias current for each tube ; otherwise distortion will rise quickly. One other solution would be to have 1 primary for each tube and there the transformer will be much more costly... So going after more than 2 tubes in parallel in SE mode is not douable for you! with 6550's. It's why so few designs exists! One Italian designer did a 3 * 6550 SE but uses custom made automatic bias adjustment, and special opt's ... A design has been published by Ari Polisois in AudioXpress last year using 3 parallel 6C33C-B tubes in SE configuration to get 45 watts ; but it's not a simple project! {custom SE opt's ; big heat dissipation and a bigger PS } Further to get 40 watts pure class A in SE you need a tube {'s} with a plate dissipation of more than 140 watts ; and with low internal impedance. And a costly SE opt to get the best of this mode. Very few tubes with those type of parameters exist! Regards. Alain. |
#10 | |
diyAudio Chief Moderator
JP1 on the schematic? |
| 6550 Triode B+ | deicide67 | Tubes / Valves | 4 | 21st January 2009 03:45 PM |
| Driving the kt88/6550 in set mode | duderduderini | Tubes / Valves | 0 | 15th October 2008 12:38 PM |
| Looking for EL34 PP Schematic Amp ? at least 35Watt | calico88 | Tubes / Valves | 24 | 23rd January 2007 06:05 AM |
| Using a spdt switch to select between triode mode and pentode mode on a guitar amp. | G | Tubes / Valves | 19 | 15th March 2006 09:15 AM |
| Onkyo DX-6550 Service Mode? | drax | Digital Source | 2 | 9th November 2005 08:58 PM |
| Page generated in 0.14799 seconds (60.78% PHP - 39.22% MySQL) with 11 queries |
