GU-19-1 Russian tube
I notice that the G2 dissapation max (60w) is greater than an anode max (40w).
From what I gather, RF tetrodes will generally accept higher than specified G2 voltage, providing the anode volts are kept down.
So, could this be a good contender for triode connection?
Just conjecture.
I think this is an experimenters tube.
Edit:
He he, just noticed the common G2 between sections. That'll spoil it.:xeye:
Edit2:
Which is why the dissapation is higher:rolleyes:
diyAudio Senior Member
Joined 2002
WHAT'S IN A NAME.
Glad I could help.
From looking at your name I assume you live in Belgium or France so if you don't mind you have a good chance of finding what you need here:
HALFIN INTL
You can send Mr.Michel Wiams an e-mail or call him directly at this # 02.209.29.01.
Hope it helps,
Cheers,;)
