| diyAudio Sponsor | ||
Should there be a load on the amp whilst biasing the valves? Is conecting to the speakers ok? And I am right aren't I in thinking biasing is done without any signal feeding into the amp?
Thanks for viewing. Matt
Matt |
#2 |
Yes, connect a load- speakers or a 10-20 ohm resistor, it's not critical. No signal. Should be easy for you.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
Thanks. Greatly appreciated.
Matt
Matt |
| Swap Shanling CD-T80 valve CD player for Quad valve equiment | johnm | Swap Meet | 2 | 24th September 2009 12:15 PM |
| low-biasing or high biasing in Class-AB amps | Workhorse | Solid State | 124 | 18th October 2005 04:45 AM |
| Convert a non-valve amp to a Valve (tube) Amp | seanthomas46 | Tubes / Valves | 11 | 6th September 2005 09:52 PM |
| SOZ Biasing | vdi_nenna | Pass Labs | 21 | 2nd June 2001 03:38 AM |
| Page generated in 0.06263 seconds (68.65% PHP - 31.35% MySQL) with 10 queries |
