diyAudio Sponsor
Old 4th January 2007, 01:34 PM   #1
knubie is offline knubie  Norway
knubie's Avatar
Default Scoundrel days
Where is the best place to look for a suitable LT supply transformer 10-15V with 0.5 - 3 Amps capacity.
There must be millions of gadgets thrown away in the trash everyday, so why pay for this...
Maybe older, smaller transistor amps can be slayered as an organ donor?
Other electrical appliances come to mind?
If it's stuck, force it... If it breaks, what the hell, it needed replacement anyways....
Amateurs fixing a fault: they succeed but then discover another fault in addition to the part they just broke....
Old 4th January 2007, 04:33 PM   #2
Send a message via AIM to DigitalJunkie
Maybe an old battery charger?
Some old printers used big linear supplies.
Old 4th January 2007, 09:38 PM   #3
knubie's Avatar
Cool, battery chargers I have, I'll check one for my old powertools, where there is no more power in the tool...
How old do you recon the printers have to be, before the mid nineties or so? thx
Old 4th January 2007, 11:14 PM   #4
aletheian's Avatar
Old printer power supplies... I get them for $1 at thrift stores. They range from 1-4 dozen volts from 2-5 amps or more depending on how beastly the printer is.
Also, old computer speaker subwoofer power supplies.
Heghlu'meH QaQ jajvam!
Page generated in 0.06945 seconds (68.99% PHP - 31.01% MySQL) with 10 queries
