| diyAudio Sponsor | ||
I have a headphone amp with a single 5842 per side that is transformer coupled to some headphones. I am getting a noise on one side that sounds like a static sound -- like a connection not being made. It sometimes turns into a squeel for a bit, and will then go away. Sometimes it goes away for hours, sometimes only for a few seconds. Also, the sound is clearly mostly on one side, but sometimes it seems to move to being on both sides, which says ground issue to me. It is the sort of thing I would typically associate with a poorly connected jack, but that doesn't seem to tbe the case.
I tried swapping the tubes and the noise stayes on the same side. I also resoldered all of the joints. I figured it was a dirty socket, but wiggling the tube doesn't seem to do anything. The tube socket is in a pcb and has 4.7K smd grid stoppers on all 4 of the grid pins. B+ is about 160V and the tube is biased with a single red (2V) LED. Any suggestion of what to look for -- unfortuatley I don't have a scope, but this is coming through OPTs and is clearly audible, so it is not ultrasonic. Any suggestions where to look? |
#2 |
Get a scope- it sounds like you have an oscillation. Tracing that down without the right tools will be an exercise in frustration.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
It happened to me, the same description of the problem, when I didn't care about heater - cathode insulation voltage. I don't think it's your case, but since you didn't post a schematic it could be
#4 |
Try swapping the 5842 from one side to the other and see if the noise follows the tube.
I have run into similar problems with other tubes as well as the 5842 and in most cases and for reasons I don't purport to understand elevating the filaments above the cathode voltage eliminated the problem. In this application 10 - 15V above the cathodes ought to be enough. The filament circuit needs a good ac ground as well. (read as shunt cap to your star ground) Another thing that may help is a very small resistor, say 10 ohms in series with the plate and right at the socket. Also I never bother with all of the other grid connections for audio use, one is sufficient. In VHF applications using all of the grid connections is important due to internal lead inductances that become relevant at those frequencies - for audio applications this is just ungainly.. Make sure those resistors are none inductive!
www.kta-hifi.net |
#5 | ||||
I fiddled with the headphone jack a bit last night, and the noise went away. So, thinking that it was just a bad jack, I replaced it and of course the noise is still there. But, after a bit of warming up, it is so intermittant so as to be non-intrusive enough, that I keep using these tubes. It is a very nice sounding tube.
[QUOTE]Originally posted by kevinkr Try swapping the 5842 from one side to the other and see if the noise follows the tube.[quote] Still there Quote:
#6 |
If you've got a copy of "Building Valve Amplifiers," there's some very useful material on troubleshooting with a scope. If you don't have that book, it's one you ought to. Somewhere on the Tektronix site, there's a very nice pdf manual ("XYZs of Oscilloscopes") on oscilloscope basics. Search around for it.
That said, the heater idea sounds very reasonable. Yes, run a voltage divider to float the heaters about 10-30V above the cathode and bypassed to ground. Again, "Building Valve Amplifiers" details this.
#7 | |
I'll still pick up a copy of the other Morgan Jones book, though. Thanks for all of the suggestions. |
#8 |
Hi Doug,
Sorry I did not get back to you last night, but I did note that SY gave you the additional information you needed to get the job done. The values you chose are just fine. Glad to hear it worked, thought it would..
www.kta-hifi.net |
| Assistance in diagnosing Hum/Buzz/Noise | xenithon | Digital Line Level | 37 | 24th January 2009 06:39 PM |
| Help diagnosing phase-splitter | pilli | Tubes / Valves | 13 | 5th July 2008 02:53 PM |
| diagnosing mains hum | baldy | Solid State | 3 | 17th October 2007 01:16 PM |
| Help diagnosing subwoofer amp | bkspero | Solid State | 22 | 1st November 2006 02:31 AM |
| Need help diagnosing plate amp. | nathank | Solid State | 7 | 2nd November 2005 07:47 PM |
| Page generated in 0.11030 seconds (86.25% PHP - 13.75% MySQL) with 10 queries |
