Marant 7c preamp diyzone project - Page 2 - diyAudio
Old 13th February 2007, 02:20 AM   #11
sandy is offline sandy  India
Default gain is the problem
I had made one such preamp...through a chinese source. The problem is the gain...it is too much for my setup.
Any ideas on how the gain can be lowered ? Changing the output buffer valve to 12AT7 or 12AU7 does not seem to help much either...
Sandy.
Old 13th February 2007, 03:52 AM   #12
Default Re: gain is the problem
You'd have to add a resistor network to attenuate the input gain. Its way too high when used with cd source.
Sorry, I can't recall the actual values as it was implemented successfully for a friend who complained that 3 clicks of the step attenuator (built in volume control) was already too loud.
Old 13th February 2007, 10:17 AM   #13
Default exactly the same problem
Exactly the same issues....even first point of the attenuator is too loud !!
Old 14th February 2007, 05:15 AM   #14
kmtang is offline kmtang  Canada
kmtang's Avatar
My friends and I all built the Marantz M7 line amp as our reference for enjoying the music. We all using Tube Regulated Power Supply for B+ and stabilized 12Vdc for the filament supply.
The results are very remarkable and outstanding.
Besides, I also built another one using 12SL7 and 12J5 instead of the 12AX7 and 12AU7 for amplication and bugger. However, I need to tweak the bias for the 12SL7 to get good sound from it.
Johnny
Please help, Marant CD80 is not working properly! chlo Digital Source 5 5th February 2013 02:43 AM
Wow, another DIYZone Pass Clone hifimaker Pass Labs 77 5th May 2010 02:54 AM
DIYZONE and IP Nelson Pass Pass Labs 49 22nd May 2005 04:31 AM
diyzone KIT. Any understandable language? styudha Digital Source 4 4th September 2003 03:43 PM
Copyright 1999-2017 diyAudio
