Checking spice model plate curve accuracy
Old 30th December 2006, 04:48 PM   #11
aletheian is offline aletheian  United States
aletheian's Avatar
Originally posted by Robert McLean
If you search this forum for "Curve Captor" you will find a very useful program for generating triode spice models.
I have downloaded Curve Captor... both Mac and Win binaries, but I can't get them to compile properly on either platform. I did manage to get the Windows version to "compile", there were a few errors, so it crashes shortly after startup. I even e mailed Andrei about a year ago, and followed his instructions, but no go.
Maybe that'll be my new year's resolution... to get that program running.
Heghlu'meH QaQ jajvam!
Old 30th December 2006, 09:27 PM   #12
lndm is offline lndm  Australia
Andrei has a few models on his site
http://home.netcom.com/~wb2jia/tubes/spice3.txt
Most recently I used his 417A model on this page. There are several models for each valve, you need to switch the comment marks to select one. I use Circuitmaker 2000 and I needed to change the syntax (m to e-3) within the line of interest and then imported it.
Korens model is there for the 417. I think the 12AX7 is on the previous page in Andreis site but I don't recall whether Korens version is there.
Old 31st December 2006, 03:57 AM   #13
aletheian's Avatar
i have been tweking the parameters by hand, and I have a 12ax7 and 6sn7 based on a curve captor anode model that someone traced out... almost dead on the data sheets now, but it is a lot of tweaking and trial and error. What i REALLY need to do is get ahold of some traces of new manufacture tubes so that I can design models around them.
Old 31st December 2006, 12:18 PM   #14
Joel is offline Joel  United States
Joel's Avatar
I used CurveCaptor to generate models for 6SN7, 12AX7, 12AU7, 12AT7, ECC88, 6C4Pi, and 6C45Pi.
http://www.joeltunnah.com
Old 31st December 2006, 06:20 PM   #15
aletheian's Avatar
hey Joel. I have been meaning to thank you for posting those, but I haven't seen you around in the last few days.
I have been using models based on the equasions in your models quite a bit this week. Since I can't get Curve Captor to work, the next best thing is finding someone else's traces and tweaking them. They are getting pretty close. They were close to begin with, but i am trying to average the curves from a bunch of data sheets and also make the model work better at higher grid bias levels.
Old 1st January 2007, 02:40 PM   #16
Joel's Avatar
I used the GE datasheets for most of them. Good traces are harder to come by for the Russian tubes.
Joel
Checking spice model plate curve accuracyHide this!Advertise here!
Help With 6v6 Spice Model porcatroya Tubes / Valves 0 5th May 2008 07:41 AM
Spice simulators and accuracy results rtarbell Everything Else 35 1st June 2007 12:37 AM
2C36 plate curve G33/33 Tubes / Valves 2 21st November 2006 01:27 AM
Plate curve calculations - am I doing this right? Saurav Tubes / Valves 12 25th June 2003 08:51 AM
Spice model for LED? G Solid State 5 14th September 2002 04:33 AM
Copyright ©1999-2017 diyAudio
