diyAudio Sponsor
Old 28th December 2006, 08:46 AM   #1
pascde is offline pascde  Canada
Default dynaco st35 clone problem
Hi
The power transformer of this little amp is dead. I have in stock a tranformer that have 295-0-295 volt with 120 ma. Did 120 ma is enought for this little amp.
PAscal
Old 28th December 2006, 09:09 AM   #2
Pascal,
The trafo you have is not suitable for service in a ST35. The spec's for the ST35 power trafo are here.
Triode Electronics carries an exact replacement for 59.95 USD.
Eli D.
Old 28th December 2006, 03:37 PM   #3
Hi Eli
What do you think of Hammond transfo. In the DIYtube paper for this amp they recommand the 270HX.
Pascal
Old 28th December 2006, 03:54 PM   #4
Tom Bavis's Avatar
Good choice - 650 VCT @ 200 mA, 6A heater.
Dynaco ST35 boards manonon Tubes / Valves 0 22nd February 2009 08:45 PM
Dynaco ST35 power? KJ2005 Tubes / Valves 15 15th August 2008 01:47 PM
Dynaco ST35 sds2000 Tubes / Valves 31 4th January 2007 04:06 AM
Wanted: Dynaco ST35 Family Swap Meet 0 28th October 2005 04:44 AM
Selling Dynaco ST35 mozfet Swap Meet 0 14th January 2003 02:31 PM
Page generated in 0.06623 seconds (70.85% PHP - 29.15% MySQL) with 10 queries
