| diyAudio Sponsor | ||
I was wondering if anyone has had any trouble with the cheaper $18 Edcor OPT's as far as noise and the wiring connections are concerned? Since the primary and secondary taps are all on the same side how is the best way to minimize any noise issues?
Thanks in advance. |
#2 |
Just be sure the power transforner is turned 90 degrees and the grounding is to a star, and you won't have any problems.
#3 |
Planned on that. In fact the PT will be at one end and the OPT's at the other similar to Audiotropics Machine. It just seems like there would be less problems by bringing in the B+ on one side of the transformer, while the output would be on the other near side near the edge of the chassis. I'm going to have to cross the secondaries at some point with the B+ I think.
#4 |
Haven't got to your e-mail yet. I have been either chained to my computer at work, or traveling 500 miles 6 out of the last 8 weekends to move my mother into assisted living. I got about 200 e-mails to answer.
I have had no issues wiring up the Edcors with out paying much attention to routing the wires. I have even connected them up with clip leads (don't do this at home). The signal levels are very high at this point, so noise pickup is not an issue. Just make sure any low level wiring (like the input connections) does not come near the transformers, and as stated before, make sure the power transformer is rotated 90 degrees from the OPT's. I just wish that Edcor would have put the primary leads (high voltage) on the bottom. It would make them harder to accidentally touch. Put heat shrink on the leads.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#5 |
Thanks a lot. I understand about the not having time thing. I think I might put ventilated boxes over them just because of the location of the primary connections.
#6 |
would it at all be worthwhile to try to take off the mounting bracket and pot these things? the only thing that worries me is heat dissipation.
#7 | |
http://www.clavius.org/heatxfer.html |
#8 |
Wow. That's kind of weird because on Angela's website, they have the following statement:
Please note, potting these transformers is not recommended and will void the warranty. Mark Mercer of Hammond writes ..."due to the design, our transformers will not last very long if they are potted. The design calls for air-cooling. By potting you trap the core and build up too much heat." Admittedly it's about hammond's line of 2xx-series power transformers but still. Maybe an email to the Edcor could settle this? |
#9 | |
#10 |
OK! time for me to start searching this forum about DIY potting. I don't have any fancy vacuum pump equipment but I have to admit, the aesthetics of those open-reel OPT's were most of the deterrence I had from buying them.
| Anyone used a edcor cxpp100-ms-5k OT | nhuwar | Tubes / Valves | 4 | 8th April 2009 05:51 PM |
| Edcor Site Down? Gone? anyone know anything? | Trout | Tubes / Valves | 4 | 6th April 2009 10:36 PM |
| Edcor OPT's w/ SimpleSE | awhite1159 | Tubes / Valves | 52 | 29th September 2007 03:00 PM |
| Edcor In SE Guitar Amp | Trout | Tubes / Valves | 9 | 14th September 2007 11:59 PM |
| Edcor outputs? | kegger | Tubes / Valves | 4 | 3rd February 2007 05:35 PM |
| Page generated in 0.11006 seconds (80.08% PHP - 19.92% MySQL) with 10 queries |
