diyAudio Sponsor
Old 2nd January 2007, 05:24 AM   #21
tmblack is offline tmblack  United Kingdom
can someone tell me
where or how do you buy Edcor SE transformers?
Tom
Old 2nd January 2007, 05:39 AM   #22
sorenj07's Avatar
there you go. don't hesitate to ask them for a quote for custom jobs, they're VERY reasonable.
http://www.edcorusa.com/classx/
Old 2nd January 2007, 11:47 AM   #23
Saying that solids conduct heat better than anything else is too general a statement. The stuff used for potting may be a good thermal insulator. (A bit like adding roof insulation, to prevent loss of heat to the cool air.)
Some solids make good insulators but not many. In roof insulation its the air trapped in the insulation that does the job. Hot air naturally rises and is then replaced by cooler air and the insulation prevents this.
Aside from the other issues with potting material. If you transfer the heat to the cover of the pot and the surface area of that pot is not much larger than the transformer inside then you have accomplished nothing.If you simply want it to run cooler then just drill some holes around it so it will convect away or put a finned heat sink on it with heat sink glue.
Steve
steve
Old 3rd January 2007, 05:27 AM   #24
Thanks sorenj07.
I read the SE are very good.
Tom
Anyone used a edcor cxpp100-ms-5k OT nhuwar Tubes / Valves 4 8th April 2009 04:51 PM
Edcor Site Down? Gone? anyone know anything? Trout Tubes / Valves 4 6th April 2009 09:36 PM
Edcor OPT's w/ SimpleSE awhite1159 Tubes / Valves 52 29th September 2007 02:00 PM
Edcor In SE Guitar Amp Trout Tubes / Valves 9 14th September 2007 10:59 PM
Edcor outputs? kegger Tubes / Valves 4 3rd February 2007 04:35 PM
Page generated in 0.06966 seconds (69.81% PHP - 30.19% MySQL) with 10 queries
