#11 | |
In SoulMerchant's application, however, a few PF one way or another isn't going to matter much, as it isn't (hopefully) an oscillator. The capacitance of a variable cap will also change with the relative humidity. Best bet is to hook up the preamp to an Inverse RIAA network, then adjust the 270 pf cap (using a 365pF air-variable) for best response -- the 12 meg resistor will also need adjusting. When you have determined the optimal value swap out the air-variable and substitute in polystyrenes or mica for the exact value. For very small values of capacitance you can twist together a pair of wires -- called a "trick" capacitor. |
#12 |
I have in front of me my QSL card from 1968 with... a Heathkit VF-1 visible in the photo. It wasn't until I finally got a Collins 32S-1 that I ever experienced stable operating frequency.
Completely agree about the use of a trimmer to determine the right value, I just wouldn't want to leave it in. Microphony means generation of a voltage at the resonant frequency. A small voltage, I grant you (I haven't calculated an order-of-magnitude), but right at the most sensitive point for human hearing and in an environment where there's lots of vibration in the air to excite it.
If there's a sucker born every minute, where do the rest of them come from? |
#13 |
I agree, use a variable to determine the value, then replace with fixed. Judging from the 365pF caps I've used in radio stuff I can imagine they might be very sensitive to vibration right in the audio range, some of them made a nice little tone if you ran your finger over the plates.
| Engine Exhaust tuning Question? | Paradise_Ice | Everything Else | 12 | 8th February 2009 05:50 PM |
| Question about the pearl RIAA stage | lordvader | Pass Labs | 25 | 20th December 2006 12:02 AM |
| Tuning Question (Sealed) | kiowamec | Multi-Way | 9 | 23rd May 2006 07:47 PM |
| Question about port tuning | ostie01 | Subwoofers | 3 | 26th September 2005 01:30 AM |
| battery powered RIAA preamp question | Mad_K | Analogue Source | 8 | 27th October 2002 10:10 AM |
