| diyAudio Sponsor | ||
#12 |
diyAudio Moderator Emeritus
I find this site by Max Robinson contains lots of ideas for both simple and more advanced projects.
#13 |
Dear Matthias and others,
As promised I'll start here with links to some projects on the web using the Russian battery valve 2SH27L (=2J27L). First, a link to a nice collection of datasheets for this tube, with a translation of the Russian text into German: http://www.fragjanzuerst.de/rb/2SH27L.pdf Then, four links to various receiver projects (mainly "audion" receivers, in other words, simple "straight" receiver designs): http://www.jogis-roehrenbude.de/Lese...den-Audion.htm http://www.jogis-roehrenbude.de/Lese...ss/Negadyn.htm http://www.mydarc.de/dk3wi/html/mw-a...und_18v_a.html http://www.jogis-roehrenbude.de/Lese.../Audion2V4.htm A link showing some simple oscillators: http://www.elexs.de/roe2SH27L.htm Finally, some amplifier designs. A single-ended power amplifier from Hungary with 2SH27L and 4P1L: http://www.jgytf.u-szeged.hu/~kadar/...1l/page_01.htm And a push-pull amplifier from Germany with twenty-two 2SH27L tubes ! : http://www.jogis-roehrenbude.de/Lese...schreibung.htm I have built and tested a preamp stage with the 2SH27L based on the previously mentioned schematic from Hungary (University of Szeged), it works very well. I add a hand-drawn schematic, please note that the cathode resistor is a 2k Cermet trimpot. This should be adjusted in such a way that the anode voltage is 67 V (= the anode current is 2 mA). Hopefully these hyperlinks will be copied properly to the diyaudio forum, and the handdrawn schematic will be readable. Best regards, Aren van Waarde aka arensattic
Real HiFi runs hot and has only one speaker unit per audio channel. |
#14 | |
I built a regenerative reciever kit that used two 1T4 tubes, one as an RF amplifier and the other as the regenerative detector. Unfortunately one evening a while back I got the supply terminals confused and put the 45 volt B+ across the tube heaters. |
#15 |
Thx for the awesome replays. i will absolutely out the 2SH27L pre amp stage!
that was a really nice amp!btw i just ordered a Tube amp! an Dynavox VR-70E for just under 400euro i just had to buy it!modifications on an vr-70 so i had to try one out! thx again for the nice replay i will try out the nice looking schematic seems strait forward enogh. Mattias |
#16 |
It is a little busy right now, but here are some projects for the C3G pentode (I don't have experience with this tube myself): First, a few headphone amplifiers: http://www.jogis-roehrenbude.de/Lese...C3g-KH-Amp.htm http://www.jogis-roehrenbude.de/Lese...schreibung.htm http://www.jogis-roehrenbude.de/Lese...ns-C3g/c3g.htm Then, a few RIAA preamplifiers (for turntable cartridge): http://www.jogis-roehrenbude.de/Lese...schreibung.htm http://www.ak-tubes.de/ Finally, a funny tutorial about calculating preamp stages with a pentode like the C3G: http://roehrenfibel.files.wordpress....tus-2-band.pdf I must apologize for the fact that all these documents are in German (no problem for a Dutchman like me, but perhaps a problem for other readers). You may try Babelfish for a mechanical translation from German to English, also: the schematics are simple and straightforward. Best regards, Aren van Waarde
| FS: Lots of 5 tubes & Lot of capacitors (incl. Vitamin Q's) | MoodySteve | Swap Meet | 2 | 23rd June 2009 04:35 PM |
| F/S lots of tubes cheap | ltr317 | Swap Meet | 0 | 1st December 2008 05:13 AM |
| Lots of valve / tubes for sale in Leeds (UK) | Merlinb | Vendor's Bazaar | 0 | 12th October 2008 05:24 PM |
| WTT: Various tubes for 6CA4/EZ81 rectifier tubes | GordonW | Swap Meet | 4 | 27th August 2008 12:37 AM |
| Lots of parts on Ebay!!! Tubes, transformers etc... | mwmitchell | Swap Meet | 0 | 19th December 2003 06:21 PM |
| Page generated in 0.10526 seconds (82.09% PHP - 17.91% MySQL) with 11 queries |
