I've built some amps, need suggestions for a DIY preamp or line stage
Old 26th December 2006, 07:09 PM   #1
jduffy is offline jduffy  United States
jduffy's Avatar
Default I've built some amps, need suggestions for a DIY preamp or line stage
I've built a chip amp from scratch, a tube amp from a kit and would now like to build a tube preamp or line stage. Cheaper is better and I found it fun getting good parts for my chip amp at low cost.
It would be nice to find something with three lines in and two lines out. I listen mostly to jazz, blues, and classical.
Can you point me to some good schematics and plans that I should consider for this project?
Thanks for your help.
Old 27th December 2006, 01:49 AM   #2
jaymanaa is offline jaymanaa  United States
The thread of all line stage threads http://www.diyaudio.com/forums/showt...267&highlight=
"Make everything as simple as possible, but no simpler" Einstein
Old 27th December 2006, 02:39 PM   #3
kstagger is offline kstagger  United States
kstagger's Avatar
I've had good luck with the Ultrapath transformer coupled 6J5 linestage - though power supply design must be carefully designed to minimize hum. On the weird side, I really like the triode connected EF86 and C3m... very musical and they sound a bit different than the usual 12A*7 stuff.
Old 27th December 2006, 08:22 PM   #4
billbo is offline billbo  Australia
Default valve line stage preamp
If you want to build a simple and good preamp go to this link below. I have posted my scematic which I have built.
Cheers
http://www.diyaudio.com/forums/showt...0&pagenumber=5
Old 29th December 2006, 04:01 PM   #5
jduffy's Avatar
Default Thanks
Thank you for the help. I'm still considering options.
If there are more, I'd like to hear them.
Old 29th December 2006, 05:58 PM   #6
Steve Cresswell is offline Steve Cresswell  United Kingdom
Steve Cresswell's Avatar
You could try this one
I have used it for 12 months and it sounds great very low noise indeed.
PSU included.
Steve
Old 30th December 2006, 06:52 AM   #7
jduffy's Avatar
Thanks for the schematic Steve. I looked up the 6J5 and it sounds like it would work for me as I like good mids and highs as I listen mostly to jazz, blues, and classical.
Old 1st January 2007, 01:37 AM   #8
talaerts is offline talaerts  Belgium
Well, the aikido (see www.tubecad.com) should be a very good preamp, and it's handy that you can order the very high quality pcb for it.
I have -finally- started building it, using 6GM8 low-voltage tubes (needs a 24V power supply). This uses the 9-pin PCB.
Old 2nd January 2007, 08:04 PM   #9
jduffy's Avatar
I looked for an Aikido preamp but all I saw was an attenuator.
Is there in fact an Aikido preamp PCB?
Old 2nd January 2007, 08:20 PM   #10
Nordic is offline Nordic  South Africa
Nordic's Avatar
Yes, and many versions... all the rage these days...
I've built some amps, need suggestions for a DIY preamp or line stageHide this!Advertise here!
Built the DDDAC MKII USB audio card, modified it to feed SRPP tube amp line stage wa2ise Tubes / Valves 0 8th June 2008 03:21 AM
Choosing the line stage preamp. felixx Tubes / Valves 3 22nd September 2006 06:54 PM
Best line stage preamp to mate with the Zen v9? jimmyd53 Pass Labs 4 19th June 2006 11:45 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Suggestions on Balanced Line Stage - parts? lgreen Pass Labs 3 4th May 2003 03:07 AM
