diyAudio Sponsor
Old 21st December 2006, 02:23 PM   #1
draget is offline draget  Australia
Default Cheap PP OPTs
Does anyone know of a source of very cheap PP OPTs designed for use with 6V6 in PP, about 8k primary to 8ohm secondary.
Thanks,
Tom
Old 21st December 2006, 02:26 PM   #2
richwalters's Avatar
Ebay----------simple
Old 21st December 2006, 02:38 PM   #3
tubelab.com's Avatar
The Edcor XPP10-8-8K is $17 USD each. I have a pair running with 6AQ5's (miniature 6V6's) and they sound reasonable for cheap transformers.
They also have a "25 watt" version for $29 USD but I have not tried them yet. The number is XPP25-8-7.6K
www.edcorusa.com
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Toroid OPTs Fuling Tubes / Valves 34 11th April 2012 02:09 AM
Ask Jan First OPTs Psychobiker Tubes / Valves 6 2nd March 2008 09:33 AM
FS: James 5K/3.5K:8/4 10W OPTs dsavitsk Swap Meet 1 21st January 2008 06:03 PM
Toroidals as OPTs? hacknet Tubes / Valves 21 24th August 2004 05:26 PM
SE design using 10k OPTs roundel325 Tubes / Valves 7 16th June 2004 06:52 AM
Page generated in 0.06555 seconds (74.42% PHP - 25.58% MySQL) with 10 queries
