| diyAudio Sponsor | ||
Hello,
Do any one have the McIntosh C-22 Com. Ed. preamplifier schematic? I need it to check a trouble with the left channel with noise sustained noise while the other one is quiet.... |
#2 |
#3 |
Thank you, Waterman, this is great help to hunt for the trouble noises....
#4 |
I'm also an Ex-owner of Mcintosh C22 CE. This pre-amp is pretty reliable. I guess the problem probably comes from the volume tuner or tube. Good luck.
#5 |
It's a constant low poping noise, looks like some resistor or capacitor....still hunting the source. Thank you. It's a pity it happen to both amplifier, my MC275CE also has problem with a output tube with red plate! Only one kt88, so, I changed the tube and problem still persist, I suspect the bias circuit. My system is on holiday........
#6 |
Tracked the noisy problem is from a 11K resistor R43 to ground in the balance output circuit. It measures over 18K. So, one problem is fixed.
#7 | |
Victor
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
| Page generated in 0.07767 seconds (73.36% PHP - 26.64% MySQL) with 9 queries |
