| diyAudio Sponsor | ||
Finally, I got the Aikido preamp working in synergy with my main system.
I owe a huge debt to Sy who looked over my circuit diagrams for PSU and inspected a poor quallity photo of my layout. With his recommendations, the amp is now hum-free, except for very minor hum from the transformer which is not getting into the signal. I am incredibly revieved. So, I learned a few things: 1. Bias the heaters to 25% of B+ to the center-tap of the heater AC transformer. 2. Mount the volume pot to the chassis 3. Ensure that the signal wiring avoids the proximity of any AC wiring. I do now need to buy a good stepped attenuator and then move my good quality jacks and source selector from my passive-preamp to Aikido. Again, I want to thank Sy for his help, and metion that this forum really benefits from his expertise and experience. Regards, Charlie |
#2 |
Glad you are now enjoying the aikido circuit. My 6SN7-based aikido brings a smile every time I switch it on...it is just so darn musical...
One comment about the stepped attenuator. I have a cheap Alpha pot, and a nice ladder stepped attenuator. Honestly, the Alpha pot sounded more lively than the stepped, altho it was a bit thin. I swapped it out for the stepped, which sounded dull and rolled off. In the end, I switched to a shunt-style setup, using a single resistor in the signal path, with just the wiper and the shunt resistors from the stepped providing a path to ground. That proved to be the ticket. If I were to do it all over again, I would forget about dropping in the stepped, and just using the Alpha pot in shunt form. All you need is 2 resistors which are the same value resistance as the pot. Start with that, first... |
| JBl GTS600, amplifier wanted! Dead or Alive, Alive if it can be helped:) | Paradise_Ice | Swap Meet | 10 | 5th August 2010 09:47 PM |
| Its alive!!! Aikido 5687 | cjkpkg | Tubes / Valves | 20 | 1st September 2009 11:02 AM |
| A new Aikido is born - and kicking butt! | cbutterworth | Tubes / Valves | 8 | 18th December 2006 06:59 PM |
| STK407-050 module alive and kicking | Tekko | Chip Amps | 27 | 17th July 2005 09:42 PM |
| I'm kicking around some sub ideas | tom1356 | Multi-Way | 6 | 25th December 2002 09:15 PM |
| Page generated in 0.07387 seconds (71.44% PHP - 28.56% MySQL) with 10 queries |
