diyAudio Sponsor
Old 18th December 2006, 03:51 PM   #1
Grahamm is offline Grahamm  South Africa
Default Spice models
Hi
I am looking for both pspice and xspice models for 6C45pi and 6H30pi tubes.
If someone can perhaps explain the syntax differences, I shall be most grateful.
Old 18th December 2006, 10:52 PM   #2
aletheian's Avatar
Here are two that i had around from someone else's site:
.SUBCKT KTRIODE A G K
+ PARAMS: MU=37.58299 EX=1.132166 KG1=428.9745 KP=402.1368 KVB=321.0256
+ LG=0.2U VBIG=-0.2 EG=1.0389 KG=0.000769 KRG=3.685584 KVG=0.090943
+ CCG=2.4P CGP=3.9P CCP=0.7P CCH=5.6P
E1 7 0 VALUE = {V(A,K) / KP * LOG(1 + EXP(KP * (1/MU + V(G,K) / SQRT(KVB + V(A,K) * V(A,K)))))}
RE1 7 0 1G
G1 A K VALUE = {(PWR(V(7), EX) + PWRS(V(7), EX)) / KG1}
RCP A K 1G ;
C1 G K {CCG} ;
C2 G A {CGP} ;
C3 A K {CCP} ;
C4 K 0 {CCH} ;
E10 10 0 VALUE = {IF(V(A) - V(K) > 0, V(A) - V(K), 0)}
E11 11 0 VALUE = {IF(V(G) - V(K) > VBIG, V(G) - V(K) - VBIG, 0)}
E12 12 0 VALUE = {(KG * (V(11) ** EG) *
+ (((KRG - 1) / (KVG * V(10) + 1)) + 1)) + LG}
G2 G K VALUE = {IF(V(12) > LG, V(12), LG)}
.ENDS
.SUBCKT 6N30P-DR A G K
X1 A G K KTRIODE
+ PARAMS: MU=14.82339 EX=1.386938 KG1=255.6717 KP=99.30537 KVB=1042.421
+ LG=0.2U VBIG=-0.1 EG=1.414474 KG=0.000769 KRG=5 KVG=0.027177
+ CCG=6.3P CGP=6.5P CCP=2.4P CCH=8P
.ENDS
Heghlu'meH QaQ jajvam!
Old 18th December 2006, 10:54 PM   #3
aletheian's Avatar
and this one:
6C45Pi Spice 3F4 model
.subckt 6C45Pi P G K
Bp P K I=(0.005984658048m)*uramp(V(P,K)*ln(1.0+(0.0202889 9001)+exp((7.114994862)+(7.114994862)*((56.6867859 5)+(336.3011671m)*V(G,K))*V(G,K)/sqrt((7.450118654e-006)^2+(V(P,K)-(-10.58802286))^2)))/(7.114994862))^(1.976888442)
Cgp G P 4pF
Cgk G K 11pF
Cpk P K 1.9pF
.ends 6C45Pi
Old 18th December 2006, 10:56 PM   #4
aletheian's Avatar
I think I got them here:
http://www.joeltunnah.com/JT_TUBELIBRARY.txt
Old 19th December 2006, 07:11 AM   #5
rdf is offline rdf  Canada
rdf's Avatar
Thx aletheian!
Old 19th December 2006, 12:16 PM   #6
Klimon is offline Klimon  Belgium
Or here (dunno if it's the same, spice is beyond me): http://digilander.libero.it/paeng/projects_frame.htm
Old 19th December 2006, 01:48 PM   #7
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
I would point out (having measured about 60 6C45):
(1) There is a big difference between "Cold War" and more recently manufactured 6C45.
(2) Even the "Cold War" 6C45 had a large spread.
(3) The published curves are rather optimistic.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 19th December 2006, 02:36 PM   #8
Default Spice Models
Thanks for the help so far. With respect to Pspice and Xspice differences, would anyone be able to tell me how to edit a pspice model 6C45 and 6H30 so that I could use it with an Xspice simulator (or the other way round for that matter)?
Spice models stinius Solid State 0 18th November 2008 10:07 PM
looking for spice models bocka Parts 16 23rd November 2003 03:00 PM
Spice Models ACR Solid State 5 24th September 2003 10:44 AM
Spice Models ACR Solid State 4 13th September 2003 05:59 PM
Page generated in 0.10076 seconds (74.87% PHP - 25.13% MySQL) with 10 queries
