diyAudio Sponsor
Old 18th December 2006, 08:41 PM   #11
richwalters's Avatar
A 6C33 is an expensive luxury and will soon be getting rare. Try parallelling other tube versions ? topcap 12E1"s are dirt cheap surplus. Or are you against pentodes ?
richj
Old 19th December 2006, 07:06 AM   #12
panos29 is offline panos29  Greece
panos29's Avatar
Send a message via ICQ to panos29 Send a message via Yahoo to panos29
I am not against pentodes at all, especially 12E1s and el509s are excellent pass elements although 6C33 is THE pass element and not expensive and rare at all, yet.
Problem is that I tried the proposed schematic and it does not work, the tube pass element is passing all the available voltage to the output. Shoud try a different topology for providing Vgk to the tube. Any ideas?
Programmable Bench Power Supply? samsagaz Parts 1 22nd January 2008 02:21 AM
Advice Needed - Power supply for Ack! dAck! TonyDasilva Digital Source 2 17th July 2005 12:50 AM
My new bench power supply Circlotron Equipment & Tools 7 28th April 2003 03:29 PM
bench power supply jethari Parts 1 14th March 2003 05:31 PM
My bench power supply.. deepanger Solid State 71 18th February 2003 07:56 PM
Page generated in 0.05269 seconds (72.50% PHP - 27.50% MySQL) with 11 queries
