| diyAudio Sponsor | ||
Dynaco Mark VI help needed by a newcomer to tube amps.
Does anyone have information on converting the Dynaco Mark VI to say a kt88 or something better? My goal is to replace the discontinued 8417 to something with the same power or better that is still in production today. I would also like to keep them at 120 watts or better. Any information would be greatly appreciated. Thank you |
#2 |
The Mark VI uses a 2200 ohm ct primary OPT. 4 KT 88's or 4 6550's will give the same relative output power with this OPT. Problem with using these substitutes is that they are not as sensitive to drive voltage as the 8417's are. This means that you will need to add an extra gain stage or redesign the amp's driver to achieve the extra drive voltage required when using the KT88 or 6550 tubes. Can be done but some / a lot of modifying will need to be done to the amps. The 8417 was one of the last tubes to be designed and marketed before solid state took over. Good ones are great... a pair will output 100 watts with very little drive voltage. There are a lot of 8417's that are prone to thermal runaway; I can't remember what brand was bad about this, I think it was GE. The 8417 closely resembles horizontal sweep tubes (6LQ6, 6JS6C, 6JE6, etc ) in performance and construction. The control grid is spaced extremely close to the cathode, hence the high sensitivity of these tubes (also this same reason causes the thermal runaway problem - unstable bias in some makes). Technically, you could use these sweep tubes for the Mark VI without redesigning the driver circuit on this amp, but you would have to redesign the output section as sweep tubes do not like more than 200-250 volts on their screens. NO ULTRALINEAR OPPERARATION! Another problem with these sweep tubes is that they have become VERY pricey as they were used in the 70-80's in linear amps for CB's, etc. Hope this helps... Daniel |
#3 |
how this go? thinking on doing the same. looking for info.
#4 |
hey-Hey!!!,
The Mk.VI has the same front end as the MK.III (which runs 6550/KT88). It should have no issue driving any of the pin compatible tubes. In the Dynaco case, it was not gain to cause troubles, it was limited voltage output. A long-tail-pair can swing a far higher percentage of its B+ compared to the split-load inverter. cheers, Douglas
the Tnuctipun will return |
#5 |
I rebuilt my MkVIs using 6550 UL, diff cascoded 6DJ8s(CCS ith negative rail from bias-winding) and E182CC as CFs. I also had separate bias for each tube.
They where quite powerful even when driving a pair of ML CLSII. If I had done it today I would have gone for triodemode and interstage transformer.
Brgds Lars |
#6 | |
cheers, Douglas
#7 |
Hi Douglas,
Forget about the mumbo-jumbo connections. Sold the junk over 10 years ago. And NFB is unfortunately necessary whatever amp you have when driving a pair of CLS. They where mean impedancewise
Brgds Lars |
#8 |
Thanks for the info so far.
Sounds like the way to go is to start with a Mark III upgrade board and add the second set of output tubes to that. Avoids the drive issues that using the default board designed for the 8417 would introduce. it does not sound like you can do enough to a Mark6 to make it behave correctly with tubes other than 8417's. of course, ideas and comments are certainly welcome. |
#9 | |
cheers, Douglas
#10 | |
Search for the audioxpress article from Kara Caffee. There you will find an upgrade on the MK III circuit which will work extremely well for the Mark VI with 8417's or 6550/kt88's. I discussed this with Kara and the above was confirmed to work in the MK VI. |
| Dynaco Mark III | Ty_Bower | Tubes / Valves | 13 | 20th February 2012 07:44 PM |
| Dynaco Mark III | Kilowatt | Tubes / Valves | 11 | 29th July 2008 01:37 AM |
| Trade 2-Dynaco Mark IV's for Coldamps | Wa | Swap Meet | 1 | 23rd January 2008 12:39 AM |
| Dynaco Information MArk II Required | jbldriven | Tubes / Valves | 0 | 25th February 2007 11:24 PM |
| Page generated in 0.12326 seconds (79.80% PHP - 20.20% MySQL) with 11 queries |
