Tentative EL84 SE Design.
Old 30th December 2002, 03:26 PM   #1
G is offline G  United States
G's Avatar
Default Tentative EL84 SE Design.
Hello all,
Sitting around the shop bored so I threw this design together using data sheets. Anyone see any problems or have any suggestions for improvements? I was thinking about using a 12AT7 instead of the 12AX7. Thanks for looking.
G
Gavin
Old 30th December 2002, 03:33 PM   #2
Joel is offline Joel  United States
Joel's Avatar
a) 8.2k is too small a load for the 12AX. Make it 100k.
b) Put a resistor inbetween the B+ output tran tap and the 50uF cap. 1,000 ohms is good.
c) Seperate 250 ohm cathode resistors for each tube.
Hmmm.... make those changes and you'll have my amp!
Old 30th December 2002, 03:34 PM   #3
Joel's Avatar
d) add a 100 ohm, 5W resistor inbetween screen and plate. It's to limit current flow for safety.
Old 30th December 2002, 03:51 PM   #4
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default THE ALFABET.
e)better still,use a separate supply for in- and output tubes.
f)better still,regulate the anode supplies for both tubes.
g)better still,up the anode supply for the 12AX7A to at least 300VDC
h)hey,and what about a volpot at the input?
Okay you got 18 characters left...
Frank
Old 30th December 2002, 04:02 PM   #5
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
g)
Then it won't be triode.
Old 30th December 2002, 04:05 PM   #6
fdegrove's Avatar
Default HOLD ON...
John??
g) was used already.
h) as well.
i)Joel suggested that already.
j)pseudo triode is a better word IMO.
Ciao,
Frank
Old 30th December 2002, 04:08 PM   #7
dhaen's Avatar
Well it was a quote
Damn, I must have started up in modulo 7 this morning
z)
Old 30th December 2002, 04:12 PM   #8
G's Avatar
I don't really want to run this in triode mode if it will stop me from getting 4 watts or so out of the circuit into an 8 ohm load.
G
Gavin
Old 30th December 2002, 04:15 PM   #9
dhaen's Avatar
Well it's drawn in triode mode.
If you want pentode mode, you'll need some NFB to make it sound reasonable IMO.
What is the impedance of the iron?
Old 30th December 2002, 04:16 PM   #10
G's Avatar
Joel, did you mean use a separate 150 ohm resistor for each EL84 cathode?
G
Gavin
Tentative EL84 SE Design.Hide this!Advertise here!
OPT Design Assistante (EL84) blindsjc Tubes / Valves 133 22nd May 2014 09:04 PM
Simple EL84 PP design needed Giaime Tubes / Valves 42 1st July 2011 04:11 AM
EL84 SE design recommendations? RockysDad Tubes / Valves 286 10th April 2009 11:58 AM
FR cab design/drivers for EL84 PP Scott ihscoutlvr74 Full Range 6 27th December 2007 06:12 PM
EL84 Triode PP Design sorenj07 Tubes / Valves 23 19th December 2007 06:01 AM
