| diyAudio Sponsor | ||
What is the term used for the 'more authoritative' (I'm looking for words) sound when comparing e.g. my 2watts el84 set with a 30watt el34 pp, speakers are about 90db/w?
Does this have something to do with headroom? I've driven 90db/W speakers with my 2W amp for a while and although I enjoy listening and definitely prefer the low-powered amp (turned less than half-way up) over the 30watt beast, the latter does have the edge when it comes to dynamics (if that's the word)... I've experienced the same thing a couple of years ago with other 90db/w speakers, another 2w set and another el34 pp so it's definitely the result of the lack of power of the little sets. It doesn't have anything to do with bandwith either, the sets have lower f3. Cheers -- Simon |
#2 |
Simon, I think you have summed it up pretty well..
Very small set amps need very, very efficient speakers to shine, at higher speaker efficiencies the smidge of dynamic compression I think I hear in some of my smaller amplifiers disappears. My 45 amp seems to compress very gradually as it runs out of steam, and there is no obvious distortion, it just is not getting as loud as it should. My daily listener is a 300B amplifier which has enough power to not exhibit this effect at any reasonable listening level with the onkens. That is until I build an even bigger SE amplifier to compare it to..
www.kta-hifi.net |
#3 |
It is called dynamic range.
However, no need for a wide dynamic range listening to some modern CDs because everything recorded on it is squized by compressors, but if you listen to a good symphonic orchestra you would love to feel the difference between mecco-piano and forte-fortissimo.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#4 |
diyAudio Moderator Emeritus
As Wavebourn says, dynamic range (DR) is the name. With a symohony orchestra or a choir, for instance, a system with inadequate DR sounds throttled. That's why we need an amp/speaker combination to have a far higher output capability than we ever intend to use for normal listening levels, just so that transients are not choked off.
#5 |
Thanks for your opinions - I'm glad I didn't simply get the answer: "you need atleast 10watts to drive 90db/w speakers"
Well - time for more efficient speakers! Simon |
#6 |
Or a line-level filter would probably also bring an improvement. Say F3 at 80-100hz; relieving the tiny-amps of the lowest octaves. What do you think?
Simon |
#7 | |
You may use also a compressor (for example, a bulb in parallel with a speaker and a photo resistor in parallel with a volume control pot output), in such case you save bass, but reduce dynamic range of music.
#8 |
Let's say a passive first order filter @ 100hz (small cap between tube amp volume pot and driver stage) for the set amp + an active 24db/octave low-pass fed into an active subwoofer?
The first order high pass will only attenuate 9db @ 50hz and 15db @25hz but in terms of power I think it'll mean a >90% relieve for the tube-amp. Simon |
#9 | |
Ahh..I'll take you on this one.......Mike Oldfield (just an example) Amarok----- some decompression on this.....it will "push a 50Watt amp" from basic listening levels nicely up through the power midrange. It opens up the Fender beautifully...A 20watt HiFi amp will struggle. Not all CD's are fully level compressed. There is a warning label on this CD ! richj |
| Carver TFM-25 Power Amp (Bias issues) | tgdrums1990 | Solid State | 1 | 15th August 2007 07:42 PM |
| Power Amp Distorion Issues - Please Help | Syko | Chip Amps | 12 | 9th May 2007 05:32 PM |
| power supply issues | beamnet | Tubes / Valves | 6 | 9th September 2005 11:47 AM |
| more help, power supply issues | theChris | Solid State | 15 | 11th April 2003 06:54 PM |
| help on power supply issues and more! | mwmitchell | Tubes / Valves | 2 | 16th August 2002 01:35 AM |
| Page generated in 0.10717 seconds (79.57% PHP - 20.43% MySQL) with 10 queries |
