Transformer Polarity Inversion......
Car audio retailers (and wholesalers) sell line level transformer coupled DC isolation boxes.
These can be modified to provide polarity inversion of one channel WRT the other.
This will cause the two amplifiers to run in anti-phase, and with the 4 ohm tap arrangements that Frank mentions, you have a cheap and easy means of bridging.
Eric.
Eric.
Q
Hi Eric San,
These do not have an insertion loss?
Hi Eric San,
Does anyone happen to have a inverter/tube circuit? Anyone can make a bridging circuit out of op amps. How about a real burn your fingers circuit for this application? In a brigded situation with tubes how much is to be gained by bridging? With solid state amps the power is multiplied by a factor of 3 or 4 times depending on the power supply and the circuit makeup.
Joe
Joe
You mean voltage? They need not have... depends on the turns.These do not have an insertion loss?
Actually, if it did, you could get over it by using 2.
I think the biggest drawback might be source loading.
Bye,
I don't think it's a good route for HiFI. The distortion will be complex, the load undefined.with tubes how much is to be gained by bridging?
With SS, bridging brings 2 benefits that are absent from tubes:
1) Increased power for the same supply rail.
2) Ability to use half value smoothing caps on a common supply rail.
GOLDEN GATE
Hello,
Exactly that I had in mind.
I do have a Counterpoint SA Pi phase inverter...never got around to drawing the circuit diagram.
Actually it uses one ECC88/6DJ8 as an anode follower with almost no gain.
There is a little trimpot on the frontplate to adjust gain setting but I can't hear any difference any way I turn it.
You can easily build your own with just a dual triode,all you need to know is that any single amplifying stage will invert absolute polarity.
Hello,
Cheap, Easy And Good Phase Inverter....
On my workshop system, I have one with reversing switches that I fitted on the primaries, and it works just fine for AUS$12.00 plus switches.
The secondaries need to be resistively loaded to avoid peaking in HF, but distortion is not noticeable, and I find the system is long term nicer with the transformer coupling.
Eric.
Eric.
BURNING BRIDGES
I agree,although you will get a 6 dB gain and increased power,distortion levels tend to increase as well.
How well it works will depend a lot on how the PSU is designed.
What you do when bridging a stereo amp is pretty much the same as running it in balanced mode.
If the amp was designed for that kind of use right from the outset (as some sand amps for subwoofer use and HT are) you'll be OK.
The Dynas were never designed for it.
So I would rather opt for biamping the LS than to bridge the amp if I had a set of two stereo amps.
HORSES FOR COURSES.
Yes,but your use of the xformers is rather different,isn't it?
If I recall it correctly,you use them to reverse absolute phase at the flick of a switch + you have the added advantage of isolating ground currents as well.
Yes, but he'll get most "noise" in bridge..So I would rather opt for biamping the LS than to bridge the amp if I had a set of two stereo amps
1002 Uses For A Transformer.....
"Yes,but your use of the xformers is rather different, isn't it?"
Yes, I am usually using them in stereo mode with selectable polarity reversal, but with a Y-lead I can feed the same signal into both primaries (with one channel in the inverted switch position), and connect an on-test speaker between the amplifier active outputs.
I sometimes use this setup for feeding reasonably high power (250W) into cabinets as I need to, and this setup works fine.
Yanamps does not mention if this higher power bridging mode is for a center channel or sub or something.
If so, then the transformer soloution is a quick and cheap means of trying it out, and I don't mind transformer sound, and it will likely work well for him.
Eric.
Eric.
There are numerous ways of producing inverted phase, arguably the best is using a quality transfomer. One question though. How critical will be matching phase gain? This also involves matching each amps gain quite accurately as there is no global feedback to compensate for this.
cheers
peter
cheers
peter
LOLthe ST-70 has a bridging switch built right in to it
We all got sucked in on this one.
- Tubes / Valves
- bridge mono tube amp
