SCA-35 Dynaco
SCA-35 Dynaco
Old 18th December 2006, 01:51 AM   #21
Eli Duttman is offline Eli Duttman  United States
Originally posted by stokessd
If you don't need the tone and balance controls, bypass them, the unit will sound a whole lot better without them.
Sheldon,
If the tone control circuitry goes, wouldn't the owner/thread originator be better off switching the 7199s out and 12DW7s, ala ST35, in? The extra gain the 7199's pentode section provides is no longer needed.
The power trafo has 2X 6.3 V./2.5 heater windings. Phase up the heater windings and connect them as 12.6 VCT/2.5 A. 4X EL84s as series connected pairs draw 1.52 A. A pair of 12DW7s draw 0.3 A. That adds up to 1.82 A., leaving 680 mA. on each side of the CT. That's plenty to full wave CT rectify with a MBR20200CT twin Schottky diode, cap. filter, and low drop out regulate into the 6.3 V./600 mA. of DC needed by the 12AX7 phono section tubes. I DETEST AC on phono section heaters.
Eli D.
Old 19th December 2006, 06:48 PM   #22
stokessd is offline stokessd  United States
stokessd's Avatar
Good point Eli, the one advantage to just bypassing the tone and balance control is that the mod is easy to do and easy to reverse without any other significant changes to the amp.
Sheldon
Old 19th December 2006, 08:46 PM   #23
Kent Smith is offline Kent Smith  United States
One thing that may have been overlooked is the preamp for the cartridge.... unless the turntable has one built in.
On speakers, tube amps tend to have lighter sounding bass than transistor. For that reason and the power, it's good to use larger 2-ways or 3-ways. Vintage AR or Advents (or others) with 8 inch or larger woofers usually have enough efficiency and bass. I used to have the Advent 10" 2-way.... wish I had never got rid of it!
Old 19th December 2006, 08:47 PM   #24
On Hiatus
SY's Avatar
SCA-35 Dynaco
The SCA35 has a phono stage. It's not a great one, but it does work.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 19th December 2006, 11:51 PM   #25
SY,
What say you about replacing the Dyna circuit with the "classic" circuit found in RCA Receiving tube manuals?
Eli D.
Old 20th December 2006, 12:47 AM   #26
On Hiatus
SY's Avatar
SCA-35 Dynaco
That's a step up. Still not particularly good, but not as actively bad.
Old 1st November 2009, 07:21 PM   #27
bulgin is offline bulgin  South Africa
Hey Guys
Look wot Santa brought
I got this sweet little SCA-35 last Saturday from a local flea market. About US$20 is all it cost.
I spent last weekend cleaning pots and chassis, tubes and sockets and input jacks and when everything was sparkling clean again, fed it some 220V through 40, 60 and 100W lightbulbs and have been listening to it now for a couple of days - right now with my Troughline 11 tuner.
I've had to replace the fuseholder as it had no cap, as well as fitting some new, slightly taller chassis feet.
Its long slumber seems not to have affected it too bad but I'll have to start thinking about renewing some vitals soon.
bulgin
Old 1st November 2009, 07:27 PM   #28
Another pic of my pretty one
bulgin
Old 1st November 2009, 11:45 PM   #29
kevinkr's Avatar
SCA-35 Dynaco
Looks pretty clean.. Nice,, I would definitely look into replacing the electrolytics in your baby soon. Should be available from dynakits here: Dynakitparts.com amongst others.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 2nd November 2009, 12:32 AM   #30
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
SCA-35 Dynaco
Bulgin,
What a steal... good on you.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
SCA-35 DynacoHide this!Advertise here!
Dynaco ST-410 Amp Creelove Solid State 13 4th January 2017 11:38 PM
Dynaco ST-120 botrytis Solid State 22 2nd December 2014 12:49 PM
preamp suitable for Dynaco st-70- OTHER than dynaco namatjira Tubes / Valves 3 22nd December 2011 01:21 AM
Dynaco A10 XO wising Multi-Way 0 24th March 2009 03:16 PM
dynaco st 70 c3 dcb50 Introductions 1 30th September 2008 11:20 PM
