SCA-35 Dynaco
SCA-35 Dynaco
Old 13th October 2012, 01:56 AM   #121
rhing is offline rhing  United States
rhing's Avatar
Originally Posted by jgf View Post
Wow, that looks great, excellent work! I'm sure it sounds great too, the EFB mod really transforms it. One question: Should those PECs (packaged electronic circuit) be on the phono inputs after the phono stage mod? I read those instructions, but it's not clear to me...
I retained the PECs on the phono inputs. All I modified was the phono stage board. It was fun project, but it did take a lot of time to clean the chassis and recondition all the pots, wire it neatly, and then solder everything in place. It definitely is not a stock unit, but it sure sounds a whole lot better.
I just started playing a mint condition Parlophone mono pressing of The Beatles' "Rubber Soul," and I have to say this just sounds fantastic. Playing a 1960's album on a vintage sound system is something magical.
Rich
Old 14th October 2012, 12:34 AM   #122
mr2racer is offline mr2racer  United States
mr2racer's Avatar
Hey All,
Got the EFB working and set. But the amp sounds awful. Must have done something really wrong. But about the PEC in the phono section. Is that just to allow for different input levels or is it some kind of equalization as well?
Old 12th June 2014, 01:56 PM   #123
SHyde is offline SHyde  United States
....reviving an old post....also first time posting.
I wonder if someone might guide me in the right direction to balance out me bias readings? I installed the EFB yesterday and while adjusting bias I got .193 on left and .350 on right. I tried swapping tubes back and forth with no change leading me to believe that it may be something else.
a few questions...
Am I hurting anything by using it as is?
Where should I look first to correct it?....(what is correct anyway?)
I think I saw a 10% variance was acceptable between left and right, is that right?
Thanks!
By the way, I am constantly in awe of what this little amp can do...love it.
Old 13th June 2014, 01:52 PM   #124
No reply yet.... was hoping some EFB fans would chime in....
I replaced the last set of caps on the the driver boards and tried again, it helped some. I now have .239 on left and .301 on right. Still not as close as I would like. Tried switching tubes around again and no change.
Anyone have to just replace all (PC10A?) components to get them better balanced?
These new numbers are just a smidge out of the 10% range but I'd like to see them near even.
Is there any chance I just need to break in the matched quad Gold Lion EL84's? I wouldn't think so since the difference didn't follow after swap.
Again, any help would be great.
Old 13th June 2014, 02:29 PM   #125
jgf is offline jgf  United States
Are you using new boards or original?
Double-check your 5ohm resistors at the test points. Did you add the 100 ohm screen stopper resistors? Do you have new or old coupling caps installed?
Old 13th June 2014, 02:40 PM   #126
original boards with all original resistors, all new caps.
I can check the 5 ohm test points
I did add the screen stoppers and I checked those, all good.
It sounds great and I don't have any balance issues, but I still think they should be closer matched
Old 13th June 2014, 04:37 PM   #127
I agree, the match should be better. If you swapped the output tubes from side to side, and the mismatch stayed with the channels then it seems the tubes are not the problem.
Next I would check the grid-to-ground resistors on the output tubes, all 4 should be close to the same. Also check the resistance of the output transformers from the plate and screen taps to the center tap. Each side will be a little different, but they should match closely between channels. Also check that you have good solder joints on your output tubes. If it's old solder, you might want to remove it and re-solder.
Do you have an SCA-35 or a stereo 35?
Old 14th June 2014, 05:44 PM   #128
ArtG is offline ArtG  United States
Do the output tube plate and screen voltages measure approximately the same on each channel?
What are you using as 5 ohm output tube cathode resistors? Did you purchase close tolerance resistors, or did you match them yourself?
Old 16th June 2014, 01:55 PM   #129
So I got a reply from Dave and it turns out I'm not that far off. He said the "safe" range is .22 to .32. I understand that the right channel may burn the tubes up a bit faster...but the originals sounded great...so is tube life really a concern?
I will check everything suggested more closely the next time I get it on the bench. Thanks for the help guys.
SCA-35 DynacoHide this!Advertise here!
Dynaco ST-410 Amp Creelove Solid State 13 4th January 2017 11:38 PM
Dynaco ST-120 botrytis Solid State 22 2nd December 2014 12:49 PM
preamp suitable for Dynaco st-70- OTHER than dynaco namatjira Tubes / Valves 3 22nd December 2011 01:21 AM
Dynaco A10 XO wising Multi-Way 0 24th March 2009 03:16 PM
dynaco st 70 c3 dcb50 Introductions 1 30th September 2008 11:20 PM
