getting the specs on a transformer
Old 13th December 2006, 02:44 AM   #1
pango is offline pango  United States
Default getting the specs on a transformer
I'm trying to reverse-engineer an old amp. I have the schematic, but it's rudimentary in the sense that some components are labelled without their values.
Most of it I think I can muddle through. But the transformers (two, one labelled isolation and another connected directly to the frame of the speaker, which I assume is the output trans) are not listed with any info on the schematic.
Any suggestions on how I might know which transformers to buy to replace them?
Old 13th December 2006, 01:24 PM   #2
Joel is offline Joel  United States
Joel's Avatar
The output tube type and operating point should point you in the right direction. Also the size of the iron is another clue.
Old 13th December 2006, 04:37 PM   #3
cerrem is offline cerrem  United States
cerrem's Avatar
A few quick and dirty methods can be used here...
First note the ohms of the speaker it uses....lets say it's 8 ohms...
With the amp OFF and speaker DISCONNECTED...Get some aligator clips and apply the mains 120V @60Hz across the output transformer primary winding....don't panic, this is perfectly fine...
If you feel safer to use a variac for this and slowly raise the voltage, then do that....
You basically want to get the AC voltage ratio from Primary to Secondary....Once you get that you SQUARE it and now you have the impedance ratio.....Take that and multiply by your speaker impedance ...and there you will have your plate load....
Chris
Old 13th December 2006, 05:14 PM   #4
blacklight is offline blacklight  Finland
It may be a electrodynamic speaker. In that case the transformer fixed to the speaker is there to provide a magnetic field instead of a permanent magnet. This is also called a field coil speaker. They're otfen found inside old radios. It may even serve another purpose as a choke for the power supply.
Old 18th December 2006, 01:39 PM   #5
Thanks for the advice guys. I can try to respond a bit to your suggestions/comments.
1. I no longer have the old speaker. It was pretty damaged, and not worth re-coning, so I disconnected the trans from it and tossed it. I did measure it with a DMM and it was about 8ohms (I know that's not the most reliable way to measure imped, but it's all I could do). I now have the amp running through the trans, to an 8 ohm speaker with no problems. Not saying that proves anything, just explaining the current configuration.
2. regarding the check with 120v, that doesn't sound too hard. Some questions though.
a. would I need to take the trans completely out of the circuit? (i.e., disconnect primary & secondary leads first). I can see where I'd want to disconnect the speaker of course, but what about the primary side?
b. it seems that I should be able to use any voltage and the transformer will either step it up/down by the same ratio, or is that not correct? In particular, why do I have to apply 120v? Couldn't I just apply, say, 9v and see what the output ratio is, and then do the calculations you suggested?
3. the tubes in the amp are 18GD6A, 60FXS, 36AM3
thanks again for the help
getting the specs on a transformerHide this!Advertise here!
transformer specs magelord04 Power Supplies 3 1st August 2007 04:19 PM
Transformer Specs cammy666 Tubes / Valves 1 25th June 2007 09:47 PM
Transformer Specs Gunny Instruments and Amps 1 17th January 2007 05:52 AM
looking for transformer with the following specs? matthew2456 Tubes / Valves 4 22nd August 2006 09:58 PM
