next project - diyAudio
Old 29th December 2002, 10:58 PM   #1
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
Default next project
heres my next idea.
OPTs et al are on the way, but i went to test my 807s, and one is shorted
main amp (each channel)
I wrote 12AX7 but meant 12AU7, oops..
power supply.
eye tube VU deal.
(need to change this some.. that voltage divider won't work.. too high impedance. I suppose ill just jack up the plate resistors some, on the eye..)
thoughts, etc?
Old 29th December 2002, 11:13 PM   #2
diyAudio Senior Member
fdegrove's Avatar
Default SOME THOUGHTS.
First of all I'd recommend a 6SN7 iso the 12AU7.
Never liked the sound of the 12AU7.
Or consider a 12BH7A or 12FQ7/12CGFA.
You can also safely ommit the input cap.
Also I would up the filter cap after the choke by putting a # of caps in //.
Up to 500 microF wont do any harm.
Seems you forgot the heaters too.
Frank
Old 30th December 2002, 12:00 AM   #3
Joel is offline Joel  United States
Joel's Avatar
You also forgot a volume control. Replace the 100k grid resistor with a pot. 100k-500k will work fine.
Old 30th December 2002, 12:18 AM   #4
fdegrove's Avatar
Default UP TO THE USER?
Not so.That's up to the user...he may use something called a preamp,n'est-ce pas?
Much more interesting would be to couple V1 to the 807 directly.
Ciao,
Frank
Old 30th December 2002, 12:22 AM   #5
Joel's Avatar
What's a "preamp"???
Old 30th December 2002, 12:24 AM   #6
fdegrove's Avatar
Default PREAMP
LOL.
A prehistoric device you should be familiar with?
No?
Frank
Old 30th December 2002, 12:28 AM   #7
Joel's Avatar
That's the definition of the "digital revolution"... the thing that made the preamp redundant.
Old 30th December 2002, 12:31 AM   #8
fdegrove's Avatar
Default REVOLTING.
Frank
Old 30th December 2002, 02:48 AM   #9
Yeah, I might try something else for gain.
just kickin' the idea around for now. I have a few 6CG7's, might try them. no 6SN7s though, but they're the same tube, up to a point..
I'll probably throw on volume control when I actually make it, but im usually too lazy to draw it in
Old 30th December 2002, 04:00 AM   #10
frugal-phile(tm)
planet10's Avatar
Default Re: next project
I have quite a few of these...i could spare 1 or more ...
What iron did you order?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
CDPRO2 Group Project (open source project) BrianGT Digital Source 147 8th August 2008 11:37 AM
My OLD Project....... cheap tube audio project!!! tube-lover Tubes / Valves 4 8th May 2008 09:26 PM
first project ceebmoj Full Range 5 23rd January 2008 07:51 AM
My first project, cool project. sorinsistem Solid State 3 19th January 2006 05:08 PM
Copyright 1999-2017 diyAudio
