diyAudio Sponsor
Old 11th December 2006, 03:37 AM   #1
sorenj07's Avatar
the can-shaped things are most likely capacitors, and the circled things look like wirewound resistors.
Old 11th December 2006, 03:39 AM   #2
whitelabrat's Avatar
Default Calbest help
Ok. I'm about to reveal how much of a noob I am. I'm a bit stumped by a couple parts on my Calbest tube amp, but I don't know what they are. Any ideas? My multimeter just gave up the ghost (and it was new!) so I put an order for a new one from Mouser. I'm hoping to bring this old girl up to speed, but I'll have to do some reverse engineering. Can't find schematics for this one.
Big photos! Yikes! Scroll down to the Calbest.
http://mysite.verizon.net/oldamps/
Old 11th December 2006, 01:28 PM   #3
Resistors. Interesting. Thanks for the post!
Once I get a working multimeter I'll have to measure the values and hunt down replacements.
And yes I'll have to discharge those big caps too using a 20K 5w wire wound resistor.
Old 27th February 2007, 07:18 PM   #4
Default Bad Cap
Can anyone confirm the rating on this cap? My guess puts it at 4.2uF 400V +-20%
Old 27th February 2007, 08:23 PM   #5
Svein_B is offline Svein_B  Norway
My guess would be 470 Kohm resistor. 5%.
(colors are a bit difficult to see, so it could be 4.7 M, but that would not be a likely value)
Svein.
Old 27th February 2007, 08:33 PM   #6
frank754's Avatar
It's an old tubular paper capacitor, probably should replace these guys, being so old, but sometimes they are still OK.
Opinion wise, some say "replace these immediately", very undependable due to age.
For your question though, the color codes are exactly the same as resisitors.
470K pf, which would make it a .47 uF
The 4th band (black) would make it 20% tolerance (orange is 30%, silver is 10%)
And the last band, yellow, would make it rated at 400VDC
As for your pic, reverse it 180 degrees, so that the last (separated yellow band) is at the right, then you can look at it from left to right.
Old 27th February 2007, 08:34 PM   #7
SY's Avatar
No, that's a cap. 47 are the significant figures, but I can't make out the multiplier number. Very, very unlikely to be 4u7, but 0u47 or 0u047 are entirely possible.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 27th February 2007, 08:41 PM   #8
frank754's Avatar
Thie third band also looks yellow to me, so I would stick with .47 20% 400vdc
I don't think these went up to over 1uF
Old 1st March 2007, 05:16 PM   #9
Thanks much. I've ordered a replacement part. I suppose I can verify the value with a multimeter that measures capacitance. That probably a very high voltage spot so care will be taken!
I've just picked up a quartet of EL84's too. Now I have to figure out how to set the bias. There are two pots that look like they're for the job. I just need to figure out how to take measurements.
I'm looking to do a lot of modification to this amp. For now just making this oldie safe and sound is my goal. There is just about zero information about this Calbest out there, so if anyone out there has one, please let me know!
Old 5th March 2007, 02:21 AM   #10
Took a closer look and the band that appeared to be yellow is in fact orange.
The multimeter says about 31nF
Page generated in 0.09019 seconds (78.12% PHP - 21.88% MySQL) with 10 queries
