diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Regulated PowerSupply for Frank's 6SN7 Preamp (http://www.diyaudio.com/forums/tubes-valves/91912-regulated-powersupply-franks-6sn7-preamp.html)
Vidi 9th December 2006 06:00 PM
Hi all!
I'm totally new to tube amps, but have decided to give it a try!
So, after hours of reading in the forum, I've made my choice. I will go for the LineStage designed by Frank using 6SN7GTB tube.
http://www.diyaudio.com/forums/showt...666#post235666
My problem is the powersuply. Since I do not have any clue regarding tubes, I get in trouble when I can't seem to get the ECL85 tubes from my shop (http://www.elfa.se/no).
So I was wondering if someone could help me out (either by helping me find a supply regulated by transistors), or to see if I can use any of the following tubes instead of the ECL85:
EABC80, ECC81/12AT7, ECC83/12AX7A, ECC85, ECC88/ECC189, ECH81/6AJ8, EF89, EF94/6AU6A, EL34/6CA7, EL84/6BQ5, EL86/6CW5, EZ80/6V4, 6L6GC, 6V6GT
Regards Vidar
SvErD 9th December 2006 07:52 PM
Hi, Elfa is not the place to go for tubes.... Call Motron in Oslo or check out Demostenes www shop.
Vidi 10th December 2006 12:23 AM
Hi SvErD!
Thank you very much for the tip!
I will certantly shop from Demostenes!
Regards Vidar
Resources saved on this page: MySQL 18.75%
