| diyAudio Sponsor | ||
I am in the beggining stages of learning tube amps.
I have a amp pulled from a newcomb AV-10 Turntable. I cut all of the wiring to sell the amp not planing on playing with it. I believe there was a power on button on the turntable. Would I need to connect a few wires to get power to the tubes? I appoligize for being so new to this but need to start somewhere. I would like to modify this into a guitar amp. Thanks for any help or advise. Joe |
#2 |
First of all, make sure its got a power transformer and not one of those amps that's wired directly to the AC. If it doesn't have one, thow it out because you may get a nasty shock the second you touch the strings on your guitar! Have you considered building a kit?
#3 |
You'd need to understand mains practices in order to get it fired up, and doubly so in order to get it safe, and you'd have to take extra steps here as it is out of its original environment.
Your best bet might be to put it back where it came from and reconnect it. |
#4 |
An isolation transformer between the mains output and the preamp power input would help reduce (not eliminate) the risk.
But the suggestion to put it back into the original circuit and power it up that way makes a lot of sense too. The downside of buying an isolation transformer just to perform this check would be that if the preamp turns out to be a dud, you just bought a transformer for nothing. The upside is that if you decided to mod an old amp (e.g., one from ebay) you'd almost certainly need to install such a transformer anyway. Be safe, good luck and I'll go back to lurking now.
| Tube Amp Kit for newbie | starro | Tubes / Valves | 32 | 17th July 2008 01:37 AM |
| Humming Speaker Protection relay when powering up (newbie question) | slowpoke-nl | Solid State | 4 | 21st November 2007 01:32 PM |
| Powering Up Old Tube Amps/Receivers | DreadPirate | Tubes / Valves | 3 | 21st January 2007 03:23 AM |
| Tube Newbie needs help | 5string | Tubes / Valves | 2 | 4th May 2004 10:13 PM |
| Page generated in 0.08913 seconds (72.46% PHP - 27.54% MySQL) with 10 queries |
