| Home | Forums | Articles | Gallery | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Tubes / Valves All about our sweet vacuum tubes :) |
Thread Tools |
Hi!!!
Im kind of new with tubes so I decided to make my first design of an audio amplifier. I have to design a pre for a kt88 push-pull output. I want to use 12ax7+12au7 So, the first stage is a 12ax7 voltage amplifier. The B+ power is 540V. I took the datasheet and decided to bias the 12ax7 with Vp=250V Vg=-2V Ip=1.2mA The RP with that bias is 62500ohms Rk = 2v / 1.2ma = 1K66 ohms RA = (540-2-250)/1.2mA = 240k -> 220K The bias is working fine. AV = (mu Ra)/(Rp+Ra)=77 I have lot of .47uFx630V caps so I used that for signal decoupling, and a 22uF for Rk here is the schematics: It works OK at 1khz, the gain is almost 77 but I made some measurements (with a true-RMS voltage/frequency meter) measuring Vin and Vout, and here is the results Code:
f(hz) vo/vi 10 66,25 19 70,72 28 72,97 46 74,27 70 74,37 250 75,36 700 72,57 1000 74,04 4500 47,66 10000 27,46 15000 21,76 18000 18,50 20000 16,69 30000 12,94 thanks!!! Jorge. |
#2 |
Tetsujin
You have a high source impedance and are loading the circuit down with the input capacitance of your meter (probably 100pF or a bit more) along with all the strays of the wiring. Try it again with a 10x probe.
"We all feel like that, Reggie, now and then, especially when Spring is upon us, but few of us would care to put it on our cards." — Sir Archibald Clerk-Kerr |
#3 |
thanks for your reply.
I'm using a protek 506 multimeter http://ee.fatih.edu.tr/ComLab/images/protek506.jpg Well I will have to wait for the scope that I'm planning to buy. thanks again!!! |
| Thread Tools | |
| About an hybrid LM3886 amp using 12AX7 tube | gaetan8888 | Chip Amps | 21 | 3rd November 2009 07:08 AM |
| Tube equal to one section of a 12AX7? | Pyre | Tubes / Valves | 24 | 16th June 2008 09:02 PM |
| ECC83/12AX7 Tube test query | waam68 | Tubes / Valves | 8 | 8th November 2007 07:52 PM |
| Using a 6SL7 in a tube overdrive pedal instead of 12AX7? | G | Tubes / Valves | 5 | 21st March 2005 11:34 AM |
| suitable preamp for a tube amp (kt88+12ax7) | kevinkuang | Tubes / Valves | 6 | 17th March 2005 02:22 PM |
| Page generated in 0.06743503 seconds (74.18% PHP - 25.82% MySQL) with 10 queries |
