diyAudio Sponsor
Old 8th December 2006, 08:02 PM   #1
Default 6j5 trasformer coupled driver/splitter
Hi All..
I want realize a push pull drived by a 6j5 ...transformer coupled..
How to choose the best primary impedance?
The secondary will drive directly the grids of the 6v6..
I'm in trouble how to calculate the impedance on primary.
Can anyone help me?
Thanks,
MAurizio
Old 8th December 2006, 08:30 PM   #2
Important is the primary inductance in relation to plate resistance of the tube (for the bass rollof), I calculate >10 Henrys for 1 kOhm of plate resistance (for the 6J5 more than 70 Henrys).
Regards Andreas
Old 9th December 2006, 08:42 PM   #3
Default thanks for help
HI,
Thanks for your help..so have some formulas to send me?
What do you think about ther LL 1660..? Is suitable for this application.?
Thanks again,
MAurizio.
Old 10th December 2006, 09:15 AM   #4
Default Re: thanks for help
Originally posted by Maurizio
...What do you think about ther LL 1660...
The LL1660 in connection 4:2,25+2,25 with the 6J5 or the LL1660S in connection 2,25:2+2 with two 6J5 or two systems of the 6SN7 in parallel.
Andreas
6j5 dc coupled to 12b4a as 2a3 driver alexg Tubes / Valves 23 28th October 2008 11:35 PM
Cathode-coupled Phase Splitter Formula MelB Tubes / Valves 5 14th February 2005 08:51 PM
Some questions about Van Scoyoc X-coupled splitter ray_moth Tubes / Valves 2 5th September 2004 09:17 AM
CCS loading first stage of DC coupled driver Jens Axboe Tubes / Valves 1 20th April 2004 01:32 PM
recs wanted: opamp buffer for line driver splitter zobsky Solid State 0 28th March 2004 06:58 AM
Page generated in 0.07472 seconds (75.65% PHP - 24.35% MySQL) with 10 queries
