A wiring question. - diyAudio
Old 29th December 2002, 12:49 PM   #1
G is offline G  United States
G's Avatar
Default A wiring question.
Hello all,
I have a basic question. Let's say that I have a CLCRC power supply in the amp that I'm building. The amp is a PP EL84. The two center taps from the output transformers connect at the second cap in the filter (220uF 450v). Then comes a 5K resistor in the filter section after which two wires leading to the plate resistors of two separate 12AX7's are connected at the third capacitor (also 220UF 450v). My question is this: Can I twist the ouput transformer center tap wires and the 12AX& plate wires together for the sake of neat routing without any ill effects. The wires will be at two different potentials with respect to ground. I'm thinking that the wire with the higher voltage might impose a hum into the 12AX7 plate wire but I may be splitting hairs.
G
Gavin
Old 29th December 2002, 12:53 PM   #2
diyAudio Senior Member
fdegrove's Avatar
Default TWISTED
Don't do this.
Keep the wires separate,don't twist them together.
You would induce stray capacitance and crosstalk between the stages.
Frank
Old 29th December 2002, 12:56 PM   #3
G's Avatar
Thanks Frank.
G
Gavin
Old 29th December 2002, 01:07 PM   #4
G's Avatar
Frank, when you say separate. How much separation are we talking about. One inch? Two inches?
G
Gavin
Old 29th December 2002, 01:08 PM   #5
fdegrove's Avatar
Default DIVORCING THE WIRES
An inch should do.
Frank
On/off LED wiring question gary h Tubes / Valves 16 22nd June 2009 08:20 PM
DVC Wiring Question 69stingray Multi-Way 3 6th April 2007 12:42 PM
Amp/Sub Wiring Question OKCMustangGT Car Audio 3 31st August 2006 09:14 AM
Wiring question LizardBrain Multi-Way 4 26th March 2006 03:46 PM
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
Copyright 1999-2017 diyAudio
