diyAudio Sponsor
Old 7th December 2006, 07:53 PM   #1
FastEddy's Avatar
" ... I'm now interested in building a tube pre-amp to go with it if anyone has any suggestions... "
Me too! Ideally a tube pre-amp with just a few of balanced or unbalanced (stereo) source inputs ... kit or ready made ...
Old 7th December 2006, 08:22 PM   #2
Kooka is offline Kooka  Italy
Kooka's Avatar
What about this?
Old 7th December 2006, 08:37 PM   #3
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Originally posted by Kooka
What about this?
I'll buy a board.
Old 7th December 2006, 08:48 PM   #4
billbo is offline billbo  Australia
Default tube preamp
I have designed a line level preamp using a 12au7 and a small bunch of components. Very easy to build. If you are interested I can dig it up and post/email the schematic.
Billy D...
Old 7th December 2006, 08:57 PM   #5
FastEddy's Avatar
Kooka & Billbo:
A single channel tube pre-amp?? Using dual 12au7 for balanced input??
Noticing that Kooka's board above has provisions for three full wave bridge rectifiers ... ?? is all that required for a single channel ??
Or am I mis-reading the board layout and this is a dual channel circuit??
Anyway, I could very easily be persuaded to get enough boards and parts for two complete, two channel pre-amps (2 boards or 4?).
(Oops, just spotted the double gain variable resistors indicating two channels per board.)
(Also, can or should the 12ax7 be used as substitute??)
Got schematics?
Old 7th December 2006, 08:59 PM   #6
Seabass is offline Seabass  Scotland
What about this?
What is this amp?? More details please!!
Cheers
Old 7th December 2006, 09:22 PM   #7
Kooka's Avatar
Kooka & Billbo:
Got schematics?
Yes, 2 channels.
Old 7th December 2006, 09:23 PM   #8
Kooka's Avatar
Originally posted by jleaman
I'll buy a board.
Do you really want one?
Old 7th December 2006, 11:14 PM   #9
falcott's Avatar
I'm interested in this too... maybe even a board as well
"Everything should be made as simple as possible, but not simpler." - Einstein
Old 7th December 2006, 11:25 PM   #10
Banned
1 no, 2 yes Please..
Swap Shanling CD-T80 valve CD player for Quad valve equiment johnm Swap Meet 2 24th September 2009 12:15 PM
Convert a non-valve amp to a Valve (tube) Amp seanthomas46 Tubes / Valves 11 6th September 2005 09:52 PM
Treble response with FR drivers Chip vs SS vs Valve theoracle Chip Amps 4 3rd January 2005 09:47 AM
DIY valve amp matthew2456 Tubes / Valves 3 14th August 2004 08:08 AM
valve pre amp dudemyster Tubes / Valves 4 13th April 2004 04:13 PM
Page generated in 0.10648 seconds (78.81% PHP - 21.19% MySQL) with 11 queries
