Valve Pre for Chip Amp
Old 6th January 2007, 09:40 PM   #51
magnum_1 is offline magnum_1  Italy
Hi kooka
I sent you a mail ...
I'm interesed too in your preamp..
Bye
Alessandro
Old 11th January 2007, 10:07 PM   #52
Kooka is offline Kooka  Italy
Kooka's Avatar
It's alive
Old 11th January 2007, 11:11 PM   #53
ilimzn is offline ilimzn  Croatia
You could save yourself two 220k resistors (OK, not great saving in parts or money but makes the circuit simpler) by reusing the ones from the CCS of the first stage to bias the CCS of the second stage
Old 11th January 2007, 11:14 PM   #54
Kooka's Avatar
Did it, jumped later...
Old 27th February 2007, 10:36 AM   #55
impsick is offline impsick  United States
impsick's Avatar
kooka hi i was wondering where you got that pot for eagle? i cant find that style of pot anywhere.
"Nothing happens for a reason. There are just reasons why things happen." Quote me on that. http://stores.ebay.com/AudioGrade?_rdc=1
Old 27th February 2007, 10:47 AM   #56
Kooka's Avatar
Sorry, maybe I did not understando your question, what do you mean?
Old 27th February 2007, 12:59 PM   #57
impsick's Avatar
my bad. the potentiometer in your amp design. where did you get this library file? i need pots like that for eagle soft.
Old 27th February 2007, 01:06 PM   #58
Kooka's Avatar
Got it from a friend who designed the amp, I cannot help you because I do not have it too.
Old 27th February 2007, 01:06 PM   #59
impsick's Avatar
ok cool. thanks.
Old 8th August 2007, 06:20 PM   #60
artquake is offline artquake
Default artQuake's pre 1.1
it began in 2005 with an tube output stage from a tube tuner
1.) Backward engineering stuff to learn
2.) Soldering practice
3.) at the end of practice ... now i did understand that the amplifiing faktor was 1 (so this wasn't a preamplifier ....
4.) Further a few surfings and study brought me thru This
with further work on mixing my first impressions (1.) to my final Sovtec 6H30 Tube preamp ...
This Preamp is really great and i can really recommend to rebuild
this paeg design ... you will be suprised !
regards
artQuake
the truth is somewere
Valve Pre for Chip AmpHide this!Advertise here!
Convert a non-valve amp to a Valve (tube) Amp seanthomas46 Instruments and Amps 17 20th April 2015 05:11 AM
Swap Shanling CD-T80 valve CD player for Quad valve equiment johnm Swap Meet 2 24th September 2009 01:15 PM
Treble response with FR drivers Chip vs SS vs Valve theoracle Chip Amps 4 3rd January 2005 10:47 AM
DIY valve amp matthew2456 Tubes / Valves 3 14th August 2004 09:08 AM
valve pre amp dudemyster Tubes / Valves 4 13th April 2004 05:13 PM
