diyAudio Sponsor
Old 7th December 2006, 09:19 PM   #1
korneluk's Avatar
Default Filament Transformer for 26 DHT
folks,
I'm looking for a 1.5VAC 1.5A transformer for a 26 DHT. Any ideas where I may be able to find one?
TIA,
-- josé k.
Old 7th December 2006, 09:27 PM   #2
Tweeker is offline Tweeker  United States
Use a 2.5V transformer and a 2/3 ohm resistor on each side if you must, cuts inrush down too.
Be sure your foil hat has a good low impedance ground.
Old 7th December 2006, 09:44 PM   #3
zobsky is offline zobsky  India
zobsky's Avatar
You probably want to use DC on this tube, judging from several reports. So think about using a higher voltage filament transformer, .... rectify, filter and regulate the voltage down to 1.5V.
"Any fool can know. The point is to understand" - Albert Einstein
Old 7th December 2006, 10:00 PM   #4
korneluk's Avatar
No, I am purposely experiementing with AC heating.
Old 7th December 2006, 10:21 PM   #5
zobsky's Avatar
cool, ..let us know if it works out, I have a pair of 26 at home too. make sure you get something that can support the 1A rating of the tubes.
Another possibility is connecting the filaments in series if you can find a 3V transformer (maybe others can comment on how desirable this is)
Old 7th December 2006, 10:41 PM   #6
316a is offline 316a  England
316a's Avatar
Hi ,
How about a cascade of transformers ? Something along the lines of :
primary:secondary-----primary:secondary------26
115:30-------------------------115:6
That should get you up and running , trim the voltage with series resistors if needed
cheers
316A
Old 7th December 2006, 10:54 PM   #7
Wind your own; that's what I did. 1.5 vct is a pretty easy job. Get a 5 volt or 6.3 volt filament transformer, unwind the secondary while counting the turns to get the turns per volt ratio. Then multiply that by 1.5 to get how many turns are required for 1.5 volts. Divide by half to get ct.
I am in the process of building Kevin Kennedy's 26 preamp and I have never liked DC on DHT's. I could not find a 1.5vct transformer anywhere so I just wound my own. I made a dedicated winding for each 26 tube. Maybe the hum will be too much , I guess I'll find out!
Good luck, Daniel
Old 8th January 2008, 07:25 PM   #8
zobsky's Avatar
Any results (positive or otherwise) to post regarding AC heated filaments with this tube?
Airgap for filament transformer ? Lauscher Tubes / Valves 11 29th April 2009 06:41 PM
Filament Transformer dejanm Tubes / Valves 9 8th August 2007 07:54 AM
WTB: 6.3V Filament Transformer mrdon Swap Meet 1 20th March 2006 03:36 AM
Filament Transformer cantskienuf Tubes / Valves 1 24th June 2005 02:41 AM
filament transformer vs plate transformer contaxchen Tubes / Valves 10 14th January 2005 11:43 AM
Page generated in 0.10246 seconds (74.04% PHP - 25.96% MySQL) with 10 queries
