Several reports of Black Gates failing
Old 30th December 2002, 02:39 PM   #21
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default BOOMMMM!!!
OK, Frank but you have to agree with me that using components above their maximum ratings never is a wise thing to do.
Of course I agree.
I always design with a safety margin of at least 30 to 40% when it comes to caps.
If anyone would take a look at the Caesar circuit they could have predicted it easily.
Measured voltage is already a high 85 VDC,add to that the modulated AC signal voltage and you know that 100V insulation is not enough.
Any other cap would behave as described in above post.
One of the major problems with designer software is that it usually doesn't take dynamic conditions into account.
Frank
Old 30th December 2002, 10:39 PM   #22
jeff mai is offline jeff mai  Australia
jeff mai's Avatar
Default Re: CAP FEST
Originally posted by fdegrove
So while these caps explode they open the circuit,at worst they take the cathode resistor out as well.
That's the only damage you'll have..
To the amp maybe. You could lose an eye if it happened while you were prototyping an amp without a chassis.
The BGs however conduct fully since they short the plates internally...this shorts the cathode out and the tube will go into thermal runaway...till it dies.
You could prevent this with a fuse in the cathode circuit.
BTW, the Nichicon cap failure I mentioned above was a short, not an explosion. It isn't only BG caps that fail this way!
Old 30th December 2002, 10:59 PM   #23
fdegrove's Avatar
Default BOOM BOOM.
No?
In that case I'd like to know the guilty ones.
I insist on this because it is :
A) an expensive adventure.
B)a freaking mess
C)safety??
Sorry to act like this but caps behaving in such an unexpected way can set fire to many an household.
Better safe then sorry,no?
Frank
Old 30th December 2002, 11:41 PM   #24
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Frank, I respect your knowhow a lot but please think before you start the witch trial on BG ( which you have never even used before as you said in another thread ).
What do other caps do in the same situation ? I told you some of my experience and you seem to think only BG fails this way.
Caps sometimes short or open when failure happens and sometimes they even explode in the most extreme cases. A fact despite their safety vents and all the engineering that's behind the product to prevent it from doing so. At school we did the experiment with Philips caps. They blew as well.
So:
A) an expensive adventure is always a possiblity. Could be a cheap Nichicon that causes your expensive 300B to blow.
B) a freaking mess always occurs with this kind of failure. With BG, Elna, BCComponents or whatever brand / type.
C) For safety testing one Ceasar owner should try another brand and see what happens. I advise him or her to wear safety goggles with this experiment
These things happen. For instance I have a defective Pioneer DV-K101 here that has a IR3M03A 8-pin switching regulator used well below specs for creating a negative voltage from + 12 V. Current is no higher than 100 mA. Nevertheless this IC was probably made on a monday because it managed to burn the PCB and took the DAC with it... You know that a real 230 V switch costs too much nowadays for most manefacturers of equipment. So it failed and power was still on. Could have been my household that burned. Still I don't think all these regulators exhibit the same behaviour. Mine did.
It's only audio. Member of the non modular PCB design committee
Old 30th December 2002, 11:55 PM   #25
fdegrove's Avatar
Default I RESPECT ANYTHING REALLY...
Sorry if it seemed that way...no I don't want to haunt the BG in any way.
Still,I find it worriesome to see them behave like that and for safety's sake I only want to find out other manufacturer's product behaving the same way.
No more,no less.
Pls,read what I posted before and you will understand my concern.
Frank
Old 31st December 2002, 12:10 AM   #26
jean-paul's Avatar
Hi Frank,
There is a possibility that the graphite particles in the BG's will conduct in case of using them over their maximum ratings.
I don't know. I reread tour posts and understand your concern very good. Maybe one user with such a shorted cap could send a mail to Jelmax Japan for more information on the matter of the shorting of the cap. I am still convinced that other types behave the same but maybe in a lesser degree. Reason for some concern as you stated correctly.
In the case that BG is "oversensitive" to exreme overvoltage one should always choose a cap with a very large margin, say 50 or even 100 % above the voltage that it normally sees. Is always wise to do. Comes to my mind a magazine once advised to choose the electrolytics max. voltage rating close to the actual voltage in that application. They probably didn't test BG that time.
Just think what Silmic ( with silk and hemp) or Cerafine ( with ceramics ) or OSCON ( "organic" stuff in it ) will do when exposed to extreme voltages ?!?!?
The smoke of the hemp in the Silmic's won't hurt for sure.
Old 31st December 2002, 12:21 AM   #27
fdegrove's Avatar
Default LOL
Nah,I don't think the BG is at fault.
I know Dick made a mistake though.
Since he is such a formidable chap I tend to forgive him...
Surely you don't mind anyone trying to find out other manufacturers' caps behaviour under fault conditions?
Frank
Old 31st December 2002, 12:23 AM   #28
jean-paul's Avatar
Hi frank,
if you have some Silmics to test you can always send them.
Jean-Paul
Old 31st December 2002, 12:41 AM   #29
fdegrove's Avatar
Default NO SILMIC HERE.
Sorry to say so,I don't have any fancy PSU caps...
Once again,try to find your fellow countryman's mistake by looking at the circuit diagram.
Also find me a manufacturer of elcos with shorting plates under fault condition since this can easily set the house on fire.
That is my only worry now JP.
Frank
Old 1st January 2003, 12:16 AM   #30
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Not got any input fuses then, Frank? Naughty boy...
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Several reports of Black Gates failingHide this!Advertise here!
Black Gates For Sale Thomo Swap Meet 2 25th September 2010 11:26 AM
Black Gates out, conductive polymer in... sharpi31 Parts 14 22nd February 2009 12:11 AM
Wanted: 47uF 6.3V NX Hi-Q Black Gates dtm1962 Swap Meet 1 21st August 2006 10:29 PM
Where to buy Black Gates? roibm Parts 5 23rd May 2004 12:51 PM
What Black gates are those? roibm Parts 6 9th April 2004 12:17 PM
Copyright ©1999-2017 diyAudio
