+B Power Supply Basics
Old 6th December 2006, 09:42 PM   #1
Bengali is offline Bengali  United States
Default +B Power Supply Basics
any suggestions for a good book on tube power supply designs or online sources?
there are so many designs. I'm trying to find out the basics, like after the rectification, where do you go from there, add a choke in series, add a cap, add a resistor,etc. How are the appropriate values calculated for the target voltage and to achieve the low noise, low ripple?
If I have a transformer with an output of 220V, after full wave, I have about 311V. My target voltage is 200v, less than 50mA.
If I wanted to use solid state parts to regulate it, what would you use?
thanks.
Old 6th December 2006, 10:21 PM   #2
On Hiatus
SY's Avatar
"Valve Amplifiers" 3rd edition, Morgan Jones. He treats these questions in great detail.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 6th December 2006, 10:28 PM   #3
zobsky is offline zobsky  India
zobsky's Avatar
Default Re: +B Power Supply Basics
thanks.
I'm guessing that 311 is the unloaded voltage, .. The load will affect the output voltage.
Also, reducing the first C in a CLC..... filter will bring down the voltage, and vice versa.
PSUD is a good software to play around with these values, in addition to reading up.
Hope that helps
"Not everything that can be counted counts, and not everything that counts can be counted." - Albert Einstein
Old 6th December 2006, 10:32 PM   #4
alexmoose is offline alexmoose  United States
alexmoose's Avatar
there a few important things to remember
1. V=IR
if the transformer is NOT loaded, then I is virtually 0 and there will be no voltage drop at all no matter how much R is in the Line. This becomes a real pain in the behind when you are trying to drop voltage without knowing the operating point of your tube.
2. Once again, if the Transformer is not Loaded, all of the voltages read marginally higher even with no resistance in the Line.
3. many people suggest that you usePSUD2 However in my experience it seems rather worthless unless you already have a circuit built, and you are tweaking it.
4. Have fun!
I'll be happy to answer any more questions to the best of my ability
-Moose
Old 6th December 2006, 10:38 PM   #5
Alain Dupont is offline Alain Dupont  France
Alain Dupont's Avatar
Bengali,
A nice new design from John Broskie:
http://www.tubecad.com/2006/11/blog0087.htm
I did build 2 of these for 250DC volts and 50mA load for my phono stage
Working real great!!
These can be called "regulations..."
I did use a LF356N as IC and 7mA in the IXCP 10M45 {could use a DN2470}
Ripple invisible at the scope... and no variation of output voltage between
0 and 300mA... done tests until 1.2A
regards.
Alain.
Old 6th December 2006, 10:42 PM   #6
Nordic is offline Nordic  South Africa
Nordic's Avatar
Why do they call it B+?
Old 6th December 2006, 10:42 PM   #7
dsavitsk is offline dsavitsk  United States
dsavitsk's Avatar
A couple of nice articles here including a few on beginning PS design: http://www.audioxpress.com/resource/...lass/index.htm
Old 6th December 2006, 10:43 PM   #8
anatech is online now anatech  Canada
anatech's Avatar
Hi Nordic,
B battery, positive terminal.
-Chris
Old 6th December 2006, 10:44 PM   #9
alexmoose's Avatar
correct me if I am wrong, but doesn't B refer to a battery that used to run the plates in old portable Radios? B+ being the positive Terminal
Old 6th December 2006, 10:45 PM   #10
alexmoose's Avatar
Originally posted by Alain Dupont
Bengali,
regards.
Alain.
I like the Design, any chance I could sneak a peak at the schem?
+B Power Supply BasicsHide this!Advertise here!
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 06:10 PM
Can i use a computer power supply to power audio amplifiers? destroyer X Solid State 91 25th September 2006 05:36 AM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 03:21 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 02:30 PM
Copyright ©1999-2017 diyAudio
