diyAudio Sponsor
Old 6th December 2006, 05:15 PM   #1
croat47 is offline croat47  United States
croat47's Avatar
Default Telefunken 5094
I have the possibility of picking up a Telefunken 5094 console. I have often pined for vintage consoles to re-buld and/or modernize. Is this something that could yield nice SET's? The tube compliment is as follows:
ECC85
EF89
ECH81
EF89
EABC80
ECC83
2*ECL82
EM84
This is assumed to be per channel.
Am I looking to spend a lot of money on tubes that may or may not be for the asking in the world at this time? Are the drivers possibly worth it? The price is VERY attractive...even just for chassis, console and iron to salvage.
Aaron
Old 6th December 2006, 06:05 PM   #2
ilimzn is offline ilimzn  Croatia
Default Re: Telefunken 5094
Originally posted by croat47
I have the possibility of picking up a Telefunken 5094 console... Is this something that could yield nice SET's? The tube compliment is as follows:
ECC85
EF89
ECH81
EF89
EABC80
ECC83
2*ECL82
EM84
ECC85, EF89, ECH81, and probably EABC80 are definitely not per channel as these are parts of the tuner. ECC83 is probably part of the stereo decoder, ECL82s are the audio amp and EM84 is the indicator tube for the tuner.
If it uses 2xECL82 per channel, it's a PP amp, but if I was guessing, it's one ECL82 per channel, running SET pentode or ultralinear, giving 4W or so of power output.
Old 6th December 2006, 06:15 PM   #3
croat47's Avatar
So, as I feared: this is actually a radio with a stereo out. Is it worth trying to use the transformers and tubes? If the tubes are bad...how expensive can it get to replace them...at least the gain and rectofer stages?
Are the old Telefunken speakers worth salvage?
Aaron
Old 6th December 2006, 07:36 PM   #4
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
I note that there isn't a rectifier valve. That means the rectifier is either selenium (very bad) or very early silicon (almost as bad). If it's free and nearby it's worth looking at.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 6th December 2006, 08:33 PM   #5
coresta is offline coresta  France
coresta's Avatar
Hi , i'm collecting vintage FM Tele's receivers ... they're astonishingly good also worth the effort : don't waste it !! The speakers are ALNICO and sometimes electrostatic tweeters
Old 7th December 2006, 11:59 AM   #6
croat47's Avatar
Thanks for the head's up about the rectifier. Anyone else have info there?
It's $100 and I would have to borrow a truck for a 4 hour (round trip) drive. It presently does not emit sound of any kind. So, I would be in for a repair job...or salvage of the speakers which may or may not be in great shape. The good news: the dust cover is still with it.
The thing looks like this:
Aaron
Old 17th June 2007, 01:21 PM   #7
Aaron,
I just found the same or similar unit. Did you pick up the console and are you happy with it?
Bruce
Old 17th June 2007, 06:25 PM   #8
frugal-phile(tm)
planet10's Avatar
That will surely be stereo single-ended... 6BM8s (ECL82s) are common & cheap... i have lots of the other tubes you'd be welcome too (except ECC83 & the EM84s will be a bit faded).
The drivers & the ECC83 (if an original TFK & in good condition) are probably worth enuff to warrant the asking, The TFK OPTs are very nice.
If it is unworking these German consoles are a mess to work on, much as it would be sad to do so, i'd just gut it and start over. If the OPTs are meaty enuff you could do an EL84 or 6V6 SE (often the same OPTs were used across a wide range of models)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Telefunken tubes gianis Swap Meet 0 25th March 2008 10:58 PM
Oh man, my telefunken stoops... Cassiel Tubes / Valves 14 20th October 2005 05:23 PM
Telefunken TR-1500 anatech Solid State 7 15th October 2005 09:13 PM
Telefunken OB's finished Stixx Full Range 13 18th August 2005 08:00 AM
Telefunken? Swalabr Tubes / Valves 7 19th June 2004 07:26 AM
Page generated in 0.09898 seconds (79.61% PHP - 20.39% MySQL) with 11 queries
