diyAudio Sponsor
Old 6th December 2006, 11:24 AM   #1
okinawa is offline okinawa  Spain
Default My first audio proyect
Hi guys.
I´m new at this forum, but I´ve read a lot of threads here. I´m looking for a good proyect for a beginer. Two years ago I made a tube amp for my guitar and sound great, and now I decided for do the audio amp.
I found this page http://boozhoundlabs.com/howto/ does somebody make this amp? what´s it sounds? it´s a good start point for DIY proyects?
excuse me for my bad english, is an "spanghish" I´m from Madrid (Spain)
Thanks and great job.
Oki.
Old 6th December 2006, 11:40 AM   #2
Nordic is offline Nordic  South Africa
Nordic's Avatar
My suggestion would be to aim to build a good preamp first... it can be valve or solidstate. These projects are normaly not too hard and will serve as good refresher.
To it you could add good volume control and input selector maybe even a remote.... Once you have a nice preamp like that it is easy to try out diffirent amps and not have to worry about getting good components for all of them, as you reuse the preamp.
Old 6th December 2006, 11:46 AM   #3
SY's Avatar
Like most amps based on the cheap topologies of the old days (this looks very similar to the circuit used in many inexpensive record players of the 1950s), the performance will not be fantastic, but it looks like it would be a very nice way to get started. It is well documented, lots of pictures and descriptions, and the parts are not very expensive so you can make mistakes without financial pain. I'd say "go for it!"
BTW, I made my first visit to Madrid this year. What a fun city! Very nice outdoor music on the streets.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 6th December 2006, 12:54 PM   #4
diyAudio Moderator Emeritus
ray_moth's Avatar
Not wishing to spoil things but I notice the volume control in that lavout is very close to one of the two 6V6 OP tubes. This tube can get hot, so be careful not to burn your fingers if you build it that way! (Personally speaking, I would put the volume control in a different position.)
Old 6th December 2006, 01:24 PM   #5
thanks
Now I´m in truble... integrated amp or preamp + power amp. My first idea was to build one Dynaco ST70, but I haven´t found any good information place of anyone to build it .
I´m make me crazy looking for a good project with documentation on this forum.... :-(
SY, yes. madrid is a very good place for living, quite crazy, but good. We always sad "de Madrid al cielo" from madrid to heaven.
thanks.
oki.
Old 6th December 2006, 09:38 PM   #6
zobsky is offline zobsky  India
zobsky's Avatar
Originally posted by okinawa
thanks
thanks.
oki.
Build a pre-amp / linestage first, .. you will learn the basics of operating points etc.
Then learn to modify it.
Then use what you've learnt in building an integrated or powerstage.
My $0.03
"Any fool can know. The point is to understand" - Albert Einstein
Old 6th December 2006, 11:25 PM   #7
Okinawa,
Take a look at the "El Cheapo" project here.
While building an "El Cheapo" is a tough challenge as a 1st project, it is not an overreach. Plenty of help is available to get you past the rough spots. "El Cheapo" is an "integrated" amp; so, you will not have to build a preamp.
Eli D.
Old 7th December 2006, 02:07 PM   #8
Hey Eli,
It´s looks fine. Where can I found the lastest schematics of it...??
thanks,
Oki.
Old 7th December 2006, 05:46 PM   #9
scott_m is offline scott_m  United States
I believe the most current schematic for Eli's 'El Cheapo' is on page 18 of the linked thread. I built this amplifier from this schematic - with quite a bit of help along the way - and have been VERY happy with the results.
Scott.
Old 9th December 2006, 10:05 AM   #10
thanks scott,
I think that is a good choice, I hope that I can find the trafos here in Spain.
oki.
My OLD Project....... cheap tube audio project!!! tube-lover Tubes / Valves 4 8th May 2008 09:26 PM
Audio Amp Project rouslan Tubes / Valves 15 17th August 2006 09:03 PM
First Amp...First DIY Audio project... Doovieman Chip Amps 59 31st October 2003 02:23 PM
Car audio project Larr_e_boy Multi-Way 4 30th May 2001 01:23 AM
Page generated in 0.10166 seconds (77.06% PHP - 22.94% MySQL) with 10 queries
