| diyAudio Sponsor | ||
OK, first of all, I'll admit right now that this is kind of a backward way of doing things. Usually you set your eyes on a tube you want to play with before designing/searching a design that you like. Well, I just happened to find a power transformer but I've no idea what I could do with it. The secondary is rated 120V/0.6A (no CT). However, since the primary winding is rated for 220V and my mains is 230V, I get a bit more voltage from the secondary (about 136V no-load). I also have some other stuff lying around, like some tube sockets etc. I did a few simulations on PSUD, and I could build a nice 150-160V B+ supply out of this transformer. OK great! But what to power with it? Anything goes; preamps, headphone amps, power amps. Suggestions?
#2 |
A number of low- voltage tubes can be used - unlikely you'll need much of the 600 mA capacity. One more possibility - you could get about 160 mA at 300V with a doubler. Plenty for a stereo SE amp, or mono push-pull.
#3 |
Blacklight,
Tom Bavis give a GOOD hint in mentioning a voltage doubler. Your trafo will supply the B+ needs of an "El Cheapo". "El Cheapo" is an "integrated" amp that reaches full power when driven by a CDP.
Eli D. |
#4 |
Have a look at SY's Heretical Line Stage. it's easy to build and a great performer.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#5 |
How about an Aikido using 6922 valves? Should be pretty happy at the B+ your trafo can provide.
Or maybe a headphone amp?
--Sherman |
#6 |
choke loaded 12B4 ...............extensive CRCRC filter
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#7 |
WE417A / 5842 transformer-coupled headphone amplifier
#8 | |
#9 |
Ha! paulb: point taken. Wow, I never thought I'd have this many replies. Thanks for all the suggestions. I did concider that voltage doubler, and while it does seem attractive, I think I'll have to do it another time (I may be able to get my hands on another of these trafos). Looks like I'll be building an Aikido Low impedance headphone amp, since that's something I need. Thanks all, you've been most helpful, again.
| Where can found R-core Transformer? | Cephas | Parts | 37 | 30th November 2011 11:18 PM |
| Found An Old Transformer, Now What??? | xxxkahunaxxx | Tubes / Valves | 9 | 15th December 2008 11:12 PM |
| Found some nice Aleph power supply chokes today | Panelhead | Pass Labs | 0 | 3rd April 2003 12:10 AM |
| toroid Transformer as power Transformer for tube | tone | Tubes / Valves | 7 | 11th February 2003 08:57 AM |
| Page generated in 0.08829 seconds (77.11% PHP - 22.89% MySQL) with 10 queries |
