| diyAudio Sponsor | ||
Does anyone have any thoughts on using a 6AS7 on the output of either something like the tubelab se, or a small low watt guitar amp? Is the plate resistance too low, or would it be better to leave out the cathode bypass cap? I remember reading somewhere that they were essentially a pair of indirectly heated 2a3's in a single tube, but that may have just been someone's marketing.
http://www.ecpaudio.com |
#2 |
I don't have any direct experience of 6080 amplifiers but as nobody else has answered...
There's very little similarity between half a 6080 and a 2A3 other than that they're both triodes and about the same anode rating. Mind you, they're cheap... Because they're intended for series regulator use close adherence to published anode curves wasn't necessary, but for SE use that shouldn't be too much of a problem. The low anode resistance means you need a lower primary impedance for the output transformer, making it easier to make a good one. Keep the cathode bypass capacitor.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#3 |
Hi ,
Try a 5998 or 7236 which have similar Ra but higher mu than the 6AS7 so are much easier to drive . Alternatively use a Sovtek 2A3 cheers 316A |
#4 |
You can build everything with that tube. SE, PP in all classes, CathodeFollower, PPP, Circlotron, Horizon, SEPP, OTL.....
But be careful when paralleling the tubes. You will need matched tubes. An Advatage is the very low load impedance and output impedance which provides good damping factor and a cheap output transformer. Connected as Cathode Follower and with big amount of global Feedback, the damping factor is amazing good and the tube can drive every kind of Subwoofer. Of course a cheap solid state Amp is better suited for this job. The best is when you buy a box of 100 pieces of the cheap russian 6H13C, thats the russian equivalent of the 6080. Doesn't cost that much and you can match them yourself. It's a nice Cockebottle tube. But they need to be driven properly. Heres a nice schematic of an SEPP, it was successfull built by a german guy: The Article (PDF) The AMP best regards, Manta |
#6 | |
They're not the same circuit. right? also do you have a clearer drawing for the first link? I could barely read the values on the schematics. thank you |
#7 | |
how many watts does can it output? thank you. |
#8 | |
Marc |
#9 | |
#10 | |
Marc |
| Simplest 6080 or 6AS7 OTL Project? | Michael Rothacher | Tubes / Valves | 29 | 26th August 2010 09:05 PM |
| 6as7/6080 Se Otl | desperateaudio | Tubes / Valves | 103 | 6th January 2009 02:19 PM |
| Parallel Push Pull 6AS7 or 6080 | desperateaudio | Tubes / Valves | 29 | 16th March 2008 05:30 PM |
| Set 6080/6as7 | needtubes | Tubes / Valves | 34 | 28th August 2004 05:40 AM |
| 6080/6AS7/6H13C/6H5C in SE? | Colt45 | Tubes / Valves | 8 | 18th November 2002 06:56 PM |
| Page generated in 0.10456 seconds (82.74% PHP - 17.26% MySQL) with 11 queries |
