diyAudio Sponsor
Old 18th September 2007, 04:21 PM   #41
cjng74 is offline cjng74  Malaysia
thanks guys. the amp i have a lacking in terms of transparency and also on highs. what could be the reason.
in the CSS design, ex: with the plate voltage and bias, it should have 80mA. we should using the CSS to limit it at 80mA? 90mA?
is it a good idea to limit it back to 60mA. for me CSS should not fix the current lower then what suppose to be the current at the bias point. it restric the tube to be functioning correctly. am i right?
CJ
Old 18th September 2007, 07:10 PM   #42
Shoog's Avatar
Since completing my design I have increased the coupling cap to 4uf, though you could probably use a 2uf. I was getting resonance in the bass.
The things that will improve performance is to ensure that the triodes are sharing the current between themselves, this will require CCS's for each triode - not just each valve. Current balance in your output transformer is important but should be ensured by seperate CCS.
If you are using an interstage transformer, they require good current drive otherwise your top and bottom ends will suffer severly. I push 40mA through mine and I wouldn't consider much less.
Hope that helps.
Shoog
Old 19th September 2007, 07:24 AM   #43
morinix is offline morinix  United States
Talking 6080/6as7 SRPP
http://www.diyaudio.com/forums/showt...4773#post84773
The above link is an amp I am STILL very happy with. I up-graded to 5998. The 5998 needed the cathode resistors changed to 600ohm. The change gets about another 0.4 watts. This amp really does well on all types of music.
Old 19th September 2007, 07:30 AM   #44
coresta is offline coresta  France
coresta's Avatar
and how about the missing V3 grid resistor ? Is your v3 runnig A2 ?
Old 19th September 2007, 08:08 AM   #45
have anyone use the 6EM7 as the driver tube?
CJ
Old 19th September 2007, 09:12 AM   #46
Shoog's Avatar
Looks like an excellent candidate for a partial feedback driver stage. Run the first stage at 4mA -1V bias. I have attached a schematic of how I used to do it.
Shoog
File Type: jpg 6080 amplifier with interstage and ecl82 driver.jpg (54.0 KB, 385 views)
Old 19th September 2007, 02:39 PM   #47
i read the "55V + 55V : 110V + 110V" for the interstage transformer and also similar but different numbers for the OPT? what does it mean? thanks.
CJ
Old 19th September 2007, 05:57 PM   #48
Shoog's Avatar
I use a mains toroidal as my interstage transformer and my output transformer.
The interstage is a 55V + 55V : 110V + 110V. The 55V windings are wired in series and the 110V windings are used as the phase split side. IN this way I get 1:1+1.
I use mains torodials as the outputs with the 6V secondaries as the output secondary.
These work well in this setup.
You need to post your schematic so that we can see if there are any problems with it.
Shoog
Old 20th September 2007, 07:16 AM   #49
Yeah I know about the missing grid terminating resistor. I had to add a 1meg once I changed to real 6as7's. It did fine with late model Phillips 6080wa with floating grids though. I think I mentioned this on a later post on the referenced thread. As far as A2 operation I had an email once from some one accusing me of over-dissipation. All I can say is this amp has had flawless operation since 2002.
Simplest 6080 or 6AS7 OTL Project? Michael Rothacher Tubes / Valves 29 26th August 2010 09:05 PM
6as7/6080 Se Otl desperateaudio Tubes / Valves 103 6th January 2009 02:19 PM
Parallel Push Pull 6AS7 or 6080 desperateaudio Tubes / Valves 29 16th March 2008 05:30 PM
Set 6080/6as7 needtubes Tubes / Valves 34 28th August 2004 05:40 AM
6080/6AS7/6H13C/6H5C in SE? Colt45 Tubes / Valves 8 18th November 2002 06:56 PM
Page generated in 0.10675 seconds (80.80% PHP - 19.20% MySQL) with 11 queries
