diyAudio Sponsor
Old 6th January 2007, 04:18 AM   #21
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Originally posted by Shoog
This Allows you to use easily availble mains toroidals as output transformers.
What VA rating were the transformers you used ??
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 6th January 2007, 08:47 AM   #22
jarthel is offline jarthel  Australia
if I were to use a regular output xformer, what should be the specs?
also that xformer in the middle, is that what you call an interstage?
thanks again
Old 6th January 2007, 11:14 AM   #23
Shoog's Avatar
For the outputs I used something about 120VA, but I have been assured that something around 30-50VA would do better.
For the interstagers I used what I could get which I think was 30VA or 50VA. In this position the smallest availble will be a destinct improvement.
I think you would need something around 1K6. This might be very tough to source.
Indeed it is, and it works very well.
any alternative to ecl82 in octal mounting?
Try looking at the range of TV deflection tubes. There are some that have dissimilar triodes in them that might work very well. The ECL86 is rated as a better tube, but is still 9pin.
The only thing you may have to tinker with is the two feedback resistors, all other values are accurate. I don't want to take mine apart to confirm the values.
For the power supply you will need silicon rectification as getting a valve rectifier to pass 300mA of current is not easy. You might get away with using a big 55V+55V toroidal for the power transformer. I used a Microwave oven transformer as a power supply choke (don't know how effective it is as an inductor, but it makes a nice big 50R resistor).
The whole motivation for this amp was to build a stereo PP amp with just 4 valves, it looks very well.
This will probably be one of the cheapest high end amps you could ever build. It runs in pure class "A" triode. Some of the most highly respected amps in the world use interstage transformers. It also has a differential output stage. If you can live with about 7watts then go for it.
Shoog
Old 7th January 2007, 11:54 AM   #24
why toroidal?
also for the output transformers if the primaries is rated 115V, what should be the secondary rating?
also, what's the power rating of the amp? would it be suitable for 8ohm speakers?
can you please show the schematics of the power supply? I have seen designs where tube rectifiers where paralleled (thorsten's website). I think this allows greater amount of current to pass through.
thanks again.
Old 7th January 2007, 12:13 PM   #25
Shoog's Avatar
Toroidals are cheap and they perform really well. The real motivation is because of where I live there is no readily availble source of "real" outputs without incurring huge postal costs.
The design requires 6V secondaries for 4Ohm speakers, and 9V with 8ohm speakers. Don't get to hung up on this, with such low output impedance the cgoice of output transformers is more forgiving than with most designs.
I can get 7watts per channel out of this baby, which is more than enough for me. This is about the theoretical maximum for this tube without going into AB class.
There is another 6080 amp on the web which uses toroidals but a more conventional valve phase splitter. It measures very well. It runs at a higher voltage - which may suit some people. Personally I think interstage transformers have been found to be the best phase splitters availble, though they do impose certain constraints on the design - namely the need for very low impedance high current drive.
Shoog
Old 7th January 2007, 12:22 PM   #26
Shoog's Avatar
The power supply is very specific to the power transformer I had availble (a huge 1000VA toroidal), and the other bits I could cobble together. Using the PSU2 power supply design utility should allow you to create something to suit what you can lay your hands on. To be honest my exact design wouldn't be tremendously useful to you.
I really think that in this design the extra effort of using valve rectification isn't warranted. With resistance in the power supply chain, the result should be nearly identical. Using parallelled rectifiers presents risks because one valve is likely to hog the load and burn itself out. The way round this is to place resistance in the anode of the rectifier, but then we start to lose even more voltage than the waistfull rectifier itself.
Shoog
Old 22nd June 2007, 09:22 PM   #27
Hi Shooq,
Tks for sharing your 6as7-ecl82 schematic. I'm interested in building one and would like to know details of the CCS on the anode of the ecl82 pentode section.
Another question pls -- How is the interstage primary section connected in series or parallel (55+55V:110+110V)?
Thanks for your help.
Joe A
Old 27th June 2007, 09:13 PM   #28
Shoog's Avatar
Sorry for the delay in getting back to you.
I have done a radical overhaul of the amp recently and have a new schematic. I dropped the ECL82 in favour of a parallelled 5687 which does a better job.
I have attached the new schematic with the specified CCS.
The interstage transformer goes with the secondaries wired in "series" as the primary.
File Type: jpg 6080 amplifier with interstage and 5687.jpg (32.9 KB, 829 views)
Old 28th June 2007, 03:46 PM   #29
Hi Shoog,
Thanks very much for your reply. That was sure quite a change. I was hoping to build mine with ECL86 front-end (because that's the closest I have in my box).
Are there any substitutes for the 5687 which you would recommend (ecc82/88 or octal) without componentry changes. (You see I'm not good at designing circuits, I mainly copy them.)
Also what type of transistors do you use in your CCS? Naming them would make it easier to select the correct ones.
Joe A
Old 28th June 2007, 07:05 PM   #30
Shoog's Avatar
You could use the original circuit with the ECL86, and I believe it would be an improvement on the ECL82. The reason I went over to the 5687 is because the feedback constituted to high a percentage of the plate current of the triode section. This was swamping its natural response. Reducing the feedback resulted in the triode overloading at low input voltages.
The 5687 is a simpler option which has plenty of headroom and can handle the required current. There are no reasonable substitutions apart from the 6H30p which will cost more than the 5687. Before I went to the 5687 I used the pentode (triode strapped) of the ECL82 at 40mA which worked well, but struggled to give the required gain. Married to a high gain preamp you could probably use the ECL86 in the same way - but this seems a terrible waste.
I used pulls from an old computer monitor. I couldn't tell you the exact numbers and the only relevant spec is voltage compliance. 200V for the bottom one, and anything over 30V for the top one which should be high gain.
Hope that helps.
Will be away on holiday for a fortnight so wont be able to answer any more questions.
Shoog
Simplest 6080 or 6AS7 OTL Project? Michael Rothacher Tubes / Valves 29 26th August 2010 09:05 PM
6as7/6080 Se Otl desperateaudio Tubes / Valves 103 6th January 2009 02:19 PM
Parallel Push Pull 6AS7 or 6080 desperateaudio Tubes / Valves 29 16th March 2008 05:30 PM
Set 6080/6as7 needtubes Tubes / Valves 34 28th August 2004 05:40 AM
6080/6AS7/6H13C/6H5C in SE? Colt45 Tubes / Valves 8 18th November 2002 06:56 PM
Page generated in 0.13491 seconds (83.07% PHP - 16.93% MySQL) with 11 queries
