diyAudio Sponsor
Old 4th December 2006, 07:15 PM   #1
Default Help! Upgrade a Music Angel KT88
I have an amplifier with n°2 12AT7WA, n°2 12AU7 e n°4 KT88-98 tubes.
I changed all the tubes (leaving the KT88s) with NOS by Mullard.
I would like to improve the sound of this amplifier.
Any idea?
Schematic
Picture 1
Picture 2
Thank you
p.s.: I think that the schematic in the manual is incorrect....but i'm not sure...i'm a NEWBIE
Old 5th December 2006, 02:30 AM   #2
I see a good number of 4007 SS diodes in the schematic. If, as I suspect, they are 1N4007s, replacing them with UF4007s will lower the noise level in the amp.
Mullard made tubes in both small signal slots might make the sound too "round". My taste runs towards a mix of Mullard and RCA, as midrange accent is combined with "chime".
Eli D.
Old 5th December 2006, 02:30 AM   #3
leimaster,
Short of major surgery there is not a lot that can be done with this amplifier. Dashed this off in a hurry during my lunch break. I hope it is of some help.
I would start by purchasing a bag of 0.1uF/400V polypropylene Film/Foil capacitors and;
1) replace C1, C3, C11, C13, with the new caps - DON"T be tempted to make these caps larger in value. The circuit is "Williamson-ish" and the common problem with Williamson Designs is low frequency stability. Making these caps bigger WILL make any low frequency stability problem worse - don't do it
Also check the voltage across C23 and if less than 400V replace it too. Note the schematic says 0.22uF/250V that MUST be a "typo", there will certainly be more than 250V across it. If you can get a good 0.22uF Polypropylene cap of sufficeient voltage rating then replace C23, Also replace C15
2) add new (O.1uF/400V PP) caps across C5, C7, C39
3) Disable the Triode pentode Switch such that its in Triode Mode permanently. This should give better bass which is likely to be a little weak due to cascaded 15.9Hz roll offs (C1 and R23 followed by C11 and R29) - See comments at 1) above - leave those corner frequencies as is.
4) Add voltage balance resistors of 220K 1W across:
C19, C21, C35, C29, C25, C27 and the first 2 caps in the KT88 HV supply which are'nt marked.
5) replace 14 off 1N4007 with UF4007 or similar Ultrafast Soft Recovery Diodes.
Thats the end of the easy stuff - mayby stop at that and have a good listen.
Then if you really feel you must you could try:
5) Redo the bias circuit such that you have separate bias set pots for each KT88 - that is split the bottom (A side) of R29 and R31 to separate bias adjust pots (this will also require duplicating C9). These final bias filter caps could also have 0.1uF PP caps added across them.
6) Remove R27. replace with a current source wired from the common cathodes to the negative bias supply at R53/C39 junction.
Ian
Old 5th December 2006, 08:14 PM   #4
Hi.
The schematic in the manual is incorrect.
Look at the trimmers on the psu board. There are 6.
4 are biastrimmers for the kt88.
Look at r 41=10 ohm
It sits on the switch board label r4=20ohm.
I have the same amp.
Start with biastrim.
The reley is shown with power on so You have to solder the 4 resistors off the switch print and connect direct to the tube (r37/r39).
I am very happy with mine, but i need a schematic. (the reel one)
And thanks Ian, i will try som off yours stuff.
Best Regards
Soren
Old 5th December 2006, 10:01 PM   #5
One orher simple mod I did'nt think of before. Replace the 12AU7 driver tube with an ECC99.
Ian
Old 6th December 2006, 07:38 PM   #6
Thank you for the answers.
Please don't laugh
Could it be possible that this version of the amplifier have separeted bias for every KT88?
to Ian:
a) why I need to use this small caps across the bigger?
b) Replace the 12AU7 driver tube with an ECC99 have an electrical reason or it's just because their sound is better?
to Soren:
a) I asked to the shop the right schematics. If I find it ... you find too
b) this is a pic of the bottom of the (maybe) switch side pic.
What did u do to disable the Triode pentode Switch?
A big thanks again.
You are driving me in passion.
Old 6th December 2006, 07:38 PM   #7
Can anyone help.
The second grid on the kt88 is connectet via a 2.7k resistor to the anode.
On the schematic this resistor label r37/r39 is 51 ohm.
If the amp runs i triode mode, i think 2.7k is way to high.
Or am i totaly wrong.
Best Regards
Soren
Old 6th December 2006, 07:38 PM   #8
Sorry Ian...I found this one
http://basenjes.de/tubes/tips/bypass.htm
Old 6th December 2006, 08:09 PM   #9
Svein_B is offline Svein_B  Norway
Do not let the lack of an accurate schematics stop you.
Tracing a diagram from the actual amp is a good learning experience.
Looks like the 51 ohm (or whatever they may be) resistors are labelled R9,10,11,12 on the circuit board.
The 2.7K resistor could be instead of the 2 x 5.6K shown on the diagram.
SveinB.
Old 6th December 2006, 08:19 PM   #10
Thank you SveinB.
I agree.
But in your experience which is the right way to cut the triode switch?
can i use bridges?
music angel kt88 vitalstates Tubes / Valves 1 27th February 2008 04:31 PM
Please tell me how to upgrade Music Angel KT88 amplifier? hififactory Tubes / Valves 26 29th December 2007 03:04 PM
Page generated in 0.10938 seconds (80.66% PHP - 19.34% MySQL) with 11 queries
