sub out in my 300b se? Help me please.
Old 4th December 2006, 05:07 PM   #1
fergs1 is offline fergs1  Australia
Default sub out in my 300b se? Help me please.
Greetings Ladies and Gentlemen,
I have recently gone over to a ob b200 system supported by a sub and for simplicity A friend of mine put a sub out in my 300b se amp, just simply splitting the incoming and routing it to a pair of rca. The problem is the sub sounds craaaaaaaap and I need almost all of the gain afforded by the plate amp (250 watt) to get any bass signal. It must need a gain stage or something, Before this I had the cd signal going into one of those very nasty fake surround processor units with the effect turned off but it allowed me two outs, one to the 300b and one to the sub and it sounded fine apart from the fact that you can only listen to one source without unplugging stuff from the back of the amp. How should a pair of sub out's be achieved in my 300b. Many thanks in advance cheers fergs
Old 4th December 2006, 06:17 PM   #2
R.I.P.
Drive the sub with an attenuator from the 300B outputs.
Get your friend to install it.
Start with ~ in 1.5k ohm - out- ~ 100 ohm - earth.
Technically low bass will not be as clean but it should integrate
in character more seamlessly with the main speakers output.
/sreten.
sub out in my 300b se? Help me please.Hide this!Advertise here!
Best 300B SE OPT? bbaker6212 Tubes / Valves 333 7th February 2018 10:01 PM
300B like 845 rick57 Tubes / Valves 25 4th October 2012 09:19 AM
FS: for 300B (JE Labs 300B SE) builders cartman Swap Meet 2 29th October 2008 01:13 PM
* 35 watt * 300B SE = super 300B + Class A2 rick57 Tubes / Valves 4 13th July 2005 04:18 PM
WE 300B Vs &&&& Trout Tubes / Valves 22 20th December 2004 08:57 AM
