diyAudio Sponsor
Old 3rd December 2006, 05:12 PM   #1
Default Low voltage drop pass tube
Hey All,
Can someone let me know what characteristic(s) I can look for in a series pass tube candidate of a voltage regulator circuit that will ensure a lower voltage drop across the tube? Thanks..
Old 3rd December 2006, 05:26 PM   #2
Tom Bavis's Avatar
How much voltage and current? 6Y6 and 6W6 can pass a fair amount of current at low drop, but can't take a lot of voltage. EL34 and 6550 will be better for higher voltage and current. 6AS7/6080 will work if you can drive some grid current - actually any of them will require grid current for lowest possible drop...
Old 3rd December 2006, 05:50 PM   #3
Originally posted by Tom Bavis
...6AS7/6080 will work if you can drive some grid current...
The absolute maximum grid voltage for the 6080 is 0 Volt dc!
Andreas
Old 3rd December 2006, 06:32 PM   #4
Actually I did want the series tube to be able to handle high supply voltage as well as a fair amount of current and low voltage drop across the tube. Looks like the EL34 is the winner. Thanks.
Effects of voltage drop??? kyrie48 Solid State 1 25th October 2007 08:29 AM
rectifier voltage drop dsavitsk Tubes / Valves 8 10th November 2006 05:52 AM
voltage drop across a CCS... pedroskova Tubes / Valves 4 8th August 2005 07:11 PM
voltage drop ThSpeakerDude88 Chip Amps 30 19th July 2005 09:00 PM
Voltage drop AZ1 = AZ11 = RGN1064 rectifier tube Klimon Tubes / Valves 2 29th June 2005 10:19 AM
Page generated in 0.06812 seconds (82.38% PHP - 17.62% MySQL) with 10 queries
