diyAudio Sponsor
Old 2nd December 2006, 12:56 PM   #1
Default Frrank's 6Sn7 preamp...take out coupling cap??
A few months ago there was some "talk" on Frank's 6SN7 tube preamp.
It was a typical two stage common cathode, cap coupled to a line driver.
Why not direct coupling, inistead of cap coupling?
I beleive someone suggested this, but not sure of out-come....does anyone recall?
Thanks,
Charlie T.
Old 3rd December 2006, 02:54 AM   #2
I built it and its great. Why try to re invent the wheel?
Old 3rd December 2006, 11:42 AM   #3
Hi
Here you have both: with and without coupling cap!
Erik
Old 3rd December 2006, 12:06 PM   #4
Brian Beck's Avatar
Because it ought to sound better without that unneeded coupling capacitor and those extra resistors. Isn’t reinventing part of DIY?
Actually the direct-coupled cathode follower is as old as the hills. The only possible downside I can think of is stressing the grid of the CF at start-up and shut-down with rapid response SS power supplies. This situation varies greatly depending on power supply characteristics. But the 6SN7 is pretty beefy. With 6DJ8 CFs you will sometimes see a SS diode across the grid-cathode for protection. I think this should be avoided since the reverse-biased capacitance of diodes is non-linear. I always prefer gradual start-up supplies anyway (the B+ starting a few seconds after heater power was applied) .
Brian
Old 3rd December 2006, 12:45 PM   #5
Well Brian I have built both and listened to both and had others listen to both. The results were that the listeners liked the line stage with the coupling cap better. Now, there are those that would disagree such as you and say that the cap influences the sound. I don't think so in this case.
We could discuss the sonics pro and con of both the SS and tube rectification also and that is also part of DIY.
I have VR tubes for each channel in my line stage and that also has a sonic effect in my opinion.
What I meant by with my trying to re invent the wheel comment is that Frank's circuit is a proven one that many here have built.
Yes, he did post a direct coupled circuit for those that believe in the vodoo of capacitors. I've gotten a number of emails from members on this board about Frank's line stage and some like me have tried both and seem to favor the cap version.
Old 3rd December 2006, 01:39 PM   #6
Brian Beck's Avatar
Well, I can't and I won't argue about what you heard or prefer. If I'd sat next to you at your listening tests, I might even have agreed with your perceptions. But as general advice for this kind of circuit with dozens of other variables, I don't see your specific listening trial and preference as any kind of as general vindication for adding those extra parts. I have not built both these circuits exactly as drawn and have not therefore compared them as you have, although I have built numerous 6SN7 stages before, including cathode followers. So feel free to discount anything I say.
In a general sense, at best the additional cap will do little harm. It might add a tinge of flavor that that you like or is compensatory for some other existing sonic character elsewhere (and please don't get defensive; all our systems have characters that can be unwittingly compensated for). It's like seasoning a soup. But my soup stock might be different than yours. Not better or worse necessarily, just different.
It's just that it’s hard to argue in any universal sense that adding additional and technically unneeded components will make a design necessarily better. With duly noted exceptions, additional "unneeded" parts usually will only introduce new "distortions" that are not good: phase shift, dielectric hysteresis, noise, inductance. At worst, with a bad cap (which I'm quite sure you avoided), the results could be significantly worse. I don’t know what to make of your “voodoo” comment about caps. If you don’t think that coupling caps can sound different from one another, then there is probably little I can do to convince you otherwise.
An idea if you are so inclined: Cathode followers, being based upon 100% local feedback, can be subtly affected by reactive loading on the cathode (say, from cables). Even when well short of outright oscillation, I think this may explain why so many people diss the CF. If you can, try the direct-coupling option, but add a grid stopper to the CF. Vary to taste. You may also add a decoupling resistor in series with the output - say 100 ohms to 500 ohms. This will keep the cathode follower's feedback mechanism somewhat isolated from cable reactances. Perhaps your added coupling cap had just enough of the right impedance at high frequencies to damp incipient phase-margin problems in the CF. If that’s the case, direct-coupling with appropriate grid and cathode stoppers, might (note that I said only “might”) sound better to you than using the coupling cap and added bootstrapping resistors.
Brian
Which 6SN7 preamp should I build? chrisvw Tubes / Valves 48 12th August 2010 12:08 AM
The complete 6SN7 preamp Joel Tubes / Valves 103 14th March 2008 10:32 AM
6SN7 with transformer coupling DRC_YUN Tubes / Valves 1 26th October 2007 03:43 PM
Help with 6SN7 preamp tubedude63 Tubes / Valves 7 9th October 2006 12:31 AM
SE 6SN7/813 direct coupling QuarkStrange Tubes / Valves 5 4th April 2005 11:00 AM
Page generated in 0.10450 seconds (81.77% PHP - 18.23% MySQL) with 11 queries
